Tip & How-To about Audio Players & Recorders
Harmony remote is not controlling Dish Network device.
Hi. For most Dish Network devices, you will have to ensure that the remote address is set on 1 in order for it to be controlled by the Harmony remote.
To reset your Dish Network device to remote address 1, you can do the following:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button.
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
That should get the device working with your Harmony remote.
Hope it helps.
Sources: http://support.logitech.com
Program remote to replace all remotes
Hi, yes of course it is possible! First off, you have to make sure that your Dish device it set on remote address 1 in order for it to be controlled by the Harmony. Then, once you add the device to your Harmony account, if there are any functions that are missing, you can learn them right from the original remote .
Adding a device:
1. In the software, clcik 'Add Device'
2. Follow the on screen instructions.
Learning a command:
1. In the software, click 'Learn IR' next to the icon for your Dish device.
2. Go down to the bottom of the page where it says 'Learn a new command'
3. Type in a name for your command, and click 'Learn'
4. Follow the on-screen instructions.
Hope that helps you get this set up right!
Mar 17, 2010 | Logitech Harmony 700 LCD Remote Control
Trying to sync my dish remote to a Harmony remote but it doesn't sync. Have a Dishdvr 522
That should get the device working with your Harmony 700!
Hope it helps :)
Mar 10, 2010 | Logitech Harmony 700 LCD Remote Control
after programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
can,t controle my dish network dvr with my logitec harmoney 1
Hi. You will have to confir the commands to ensure that the Harmony is on the same remote address as the device.
1. In the software, click 'Settings' next to the icon for your dish device.
2. Select 'Confirm infrared commands' and click NEXT
3. Follow the screens!
That should do it.
Dec 16, 2009 | Logitech Harmony One Advanced Universal...
Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates the channel to which remote control 1 is configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your slingbox remote control per the instructions in the Slingbox documentation.
Feb 05, 2009 | Sling Media Slingbox AV Remote Control
137 people viewed this tip
 Grubhead
Grubhead
