Tip & How-To about EA - Electronic Arts Battlefield Bad Company
Battlefield: Bad Company 2 PB INIT FAILURE
EA - Electronic Arts Battlefield Bad Company Logo
why asd fuse keeps blown
You have a Chrysler , dodge , or Plymouth ? ASD Fuse supplies power to ASD relay ,if you have a Dodge , Chrysler or Plymouth vehicle . You have a short to ground , videos on you tube , how to find a electrical short ! ASD - auto shut down , this powers Ignition system , fuel injectors , O2 sensors . A short in any one of these systems will blow the fuse . O2 sensor wires get melted on exhaust pipes an manifolds ! That is if you have one of these make vehicles !
Sep 28, 2016 | Cars & Trucks
code P1388 and P1399
P1388 JEEP - ASD or CNG (compressed Gas) Relay Control Circuit Possible causes - Faulty ASD Relay (most common cause)
- Faulty CNG Relay
- ASD or CNG Relay harness is open or shorted
- ASD or CNG Relay circuit poor electrical connection
- ASD or CNG Relay poor ground or supply voltage condition
P1399 is a related to the P1388 failure.
Jun 27, 2016 | 2000 Jeep Grand Cherokee
my manuel trans. 2001 for focus has a rattle sound and vibrates a bit when starting. It seems to go away after it warms up a bit, but it is getting progressively worse and the vibration is lasting lon
I had a 1984 Mustang 4 cylinder that match the symptoms of your Ford Focus. I found that it was the core inside the catalytic converter had broke up and started to rattle. Not saying this is your problem but a possibility. Another possiblity, exhaust bumping the body of the car.
The wer wer wer sound you hear going over uneven ground is probably not related to the other mentioned. It sounds like the four wheel independent suspension adjusting to the terrain. Cool temperatures help promote this noise due to rubber bushing that your vehicle has in the suspension areas. Annoying, but considered normal. Hope this points you in the right direction and helps. Let me know what you found. Later, Todd
Feb 29, 2012 | 2001 Ford Focus
My ASD fuse is making a clicking noise and vibrating. What is the function of this fuse?
ASD fuse is called an AUTOMATIC SHUT DOWN FUSE. The ASD sense circuit informs the PCM when the ASD relay energizes. A 12 volt signal at this input indicated to the PCM that the ASD has been activated. This input is used only to sense that the ASD relay is energized.
When energized, the ASD relay supplies battery voltage to the fuel injectors, ignition coils, and the heating element in each oxygen sensor. If the PCM does not receive 12 volts from this input after grounding the ASD reley, it sets a Diagnostic Trouble Code (DTC).
May 18, 2011 | Jeep Cherokee Cars & Trucks
632 people viewed this tip
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
