Tip & How-To about Microsoft Windows Vista Ultimate Edition
Renaming The Start Button:
To rename the start button, you will need a hex editor.
My preference is UltraEdit
Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
With the hex editor, open that file and go to offset 412b6
You will see the word start with blanks between each letter
Edit it be any 5 characters or less
Save the file
Boot to DOS
Copy the existing c:\windows\explorer.exe to explorer.org
Copy explorer_1.exe to explorer.exe
You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
Note: If the partition is NTFS and you can't access the files from DOS:
Start Regedit
Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
Change the value of Shell from Explorer.exe to explorer_1.exe
Microsoft Windows Vista Ultimate Edition Logo
how can i change text of Start Button?
You Need to Modify "Explorer.exe File" To make the changes you need to locate and edit the file "explorer.exe" it's located at C:Windows. The file "Explorer.exe" is a binary file, so you will need special editor (Resource Hacker) will do. Resource Hacker is a good freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files. First Backup "explorer.exe" located at C:\Windows\explorer. You can place it in a special folder or save it to disk. You can also copy and change the file name to "explorerB.exe" (the B is for backup), then you can edit "explorer.exe".
2. Resource Hacker: In Resource Hacker the category will be using is String Table. You need to expand it by clicking on the plus sigh, then navigate down and expand string 37 followed by 1033, (For Classic Layout use number 38). On the right hand pane look for item 578 it show the word "start" this is what we are going to modify.
3. Edit start: To edit the word "start' you just double click on start so that it's highlighted, don't highlight the quotation marks on the sides of start, "start" NOT "start". The new text go's in between the quotation marks, like this "new" remember don't delete the quotation marks. So that it looks like this "new" replace new with your text. This is the old start text "start" delete start text "", inter your text "new" easy right!
4. Compile Script button: Now that you have changed the start text you need to click on the Compile Script button. After you have clicked on the Compile Script button you need to use the Save As command on the File Menu to save the altered file and give it a name. A good file name "explorernew.exe" or make your own. Don't use the Save command use the Save As commaned! Save the newly named file to the C:\Windows.
5. Modify the Registry: Now it's time to modify the registry so that your modified explorer.exe file that you created will be recognized when the user logs on your system. Go to the Start button click on it, then go to Run click on it, type regedit in the Open: field. Now Navigate download the list to "HKEY_LOCAL_MACHINE" click on the plus, to SOFTWARE, to Microsoft, to windows NT, to CurrentVersion, to Winlogon. The full string: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows NT\ CurrentVersion\ Winlogon
Look on the right pane for Shell, double click on Shell entry to open the Edit String dialog box. In the Value date: line enter the name that your used to save the modified explorer.exe file. click on OK.
Now close Registry Editor and exit Windows or log off your system, and then log back on. Now if the computer gods are happy and all went as planned you should see the new Start button with your cool text on it. Remember the force is with you!
Jul 08, 2009 | Computers & Internet
how to rename start buttom
Secret Way to Rename the Start Button Windows XP's start button's rebirthBefore Speaking Google IT. Master X
By Dragos Jijau, Software News Editor
19th of January 2007, 15:42 GMT
Adjust text size: text_minus.gif text_plus.gif
secret-way-to-rename-the-start-button-2.png It all begins with the start button. Maybe one of the most representative symbols of the Windows operating system, the start button has been present on our taskbars since Windows 95 and still hangs there along with the new Windows Vista.
Although its shape may have changed over the years, one thing remained the same: its display name, START. This is a remarkable success for the brand continuity and for Windows marketing scheme but we, the end users, may have gotten bored with it.
Nowadays, everything tends to become customizable, from a simple cell phone to an expensive car. If that's possible, why wouldn't there be available a method for renaming the start button?
By default, there is not a single option available in Windows to permit changing the name of the start button but there are always people who think and act to achieve what they want.
How it's done
There are two steps to follow in order to obtain what we want:
1. Editing the explorer.exe
2. Tweaking the registry to accept the changes.
First step
Explorer.exe is found in Windows folder and must be edited enable the renaming of the start button. Because we are dealing with a binary file, we need to use a file editor. I successfully edited the file using the Resource Hacker application. It is a free program available for download from Softpedia. Once you have downloaded it, extract all the data from the archive and run ResHacker. Now open the explorer.exe.
In the left, you can see an information tree. Expand String table > 37 or 38 (37 string is for the normal XP layout and 38 one is for the classic layout). You just select the one suitable for your Windows and then select 1033. In the right, line 578 display Start between quotes. Rename it with the desired name and then click the Compile Script button which is placed above.
It's time to save the new version of the explorer.exe. Click save as from the file menu and save it with a different name. I chose softpedia.exe.
Step two
Go to start > Run and type Regedit to open the registry editor. Look for this path:
HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows NT>CurrentVersion>Winlogon
In the right, find the "Shell" entry. Double click on it and replace explorer.exe with softpedia.exe (or whatever you renamed the edited file).
Close the registry editor and Log Off or Restart your computer. After Windows XP boots, the new start button will have the name you have chosen.
My tip is not to use long names because the start button will have to adapt in order to be able to show such names and its shape will be elongated and might not look too pleasant.
Jun 26, 2009 | Microsoft Windows XP Professional SP3 Full...
i want to change start button name
Renaming the Start button needs a few steps (Source: http://www.onecomputerguy.com/windowsxp_tips.htm)
Renaming the Start Button
  1. Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
  2. With the hex editor, open that file and go to offset 412b6
  3. You will see the word start with blanks between each letter
  4. Edit it be any 5 characters or less
  5. Save the file
  6. Boot to DOS
  7. Copy the existing c:\windows\explorer.exe to explorer.org
  8. Copy explorer_1.exe to explorer.exe
  9. You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
  3. Change the value of Shell from Explorer.exe to explorer_1.exe
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 03, 2009 | Microsoft Windows Xp Home Edition English...
Change text on Window start Button
Step 1 - Modify Explorer.exe File
In order to make the changes, the file explorer.exe located at C:\Windows needs to be edited. Since explorer.exe is a binary file it requires a special editor. For purposes of this article I have used Resource Hacker. Resource HackerTM is a freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files (*.res). It incorporates an internal resource script compiler and decompiler and works on Microsoft Windows 95/98/ME, Windows NT, Windows 2000 and Windows XP operating systems.
get this from h**p://delphi.icm.edu.pl/ftp/tools/ResHack.zip
The first step is to make a backup copy of the file explorer.exe located at C:\Windows\explorer. Place it in a folder somewhere on your hard drive where it will be safe. Start Resource Hacker and open explorer.exe located at C:\Windows\explorer.exe.
The category we are going to be using is "String Table". Expand it by clicking the plus sign then navigate down to and expand string 37 followed by highlighting 1033. If you are using the Classic Layout rather than the XP Layout, use number 38. The right hand pane will display the stringtable. We’re going to modify item 578, currently showing the word “start” just as it displays on the current Start button.
There is no magic here. Just double click on the word “start” so that it’s highlighted, making sure the quotation marks are not part of the highlight. They need to remain in place, surrounding the new text that you’ll type. Go ahead and type your new entry. In my case I used Click Me!
You’ll notice that after the new text string has been entered the Compile Script button that was grayed out is now active. I won’t get into what’s involved in compiling a script, but suffice it to say it’s going to make this exercise worthwhile. Click Compile Script and then save the altered file using the Save As command on the File Menu. Do not use the Save command – Make sure to use the Save As command and choose a name for the file. Save the newly named file to C:\Windows.
Step 2 – Modify the Registry
!!!make a backup of your registry before making changes!!!
Now that the modified explorer.exe has been created it’s necessary to modify the registry so the file will be recognized when the user logs on to the system. If you don’t know how to access the registry I’m not sure this article is for you, but just in case it’s a temporary memory lapse, go to Start (soon to be something else) Run and type regedit in the Open field. Navigate to:
In the right pane, double click the "Shell" entry to open the Edit String dialog box. In Value data: line, enter the name that was used to save the modified explorer.exe file. Click OK.
Close Registry Editor and either log off the system and log back in, or reboot the entire system if that’s your preference. If all went as planned you should see your new Start button with the revised text.[/b]
Oct 19, 2008 | Computers & Internet
377 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
