Tip & How-To about Microsoft Windows Vista Ultimate Edition
To convert a FAT partition to NTFS:
Click Start, click Programs, and then click Command Prompt.
In Windows XP, click Start, click Run, type cmd and then click OK.
At the command prompt, type CONVERT [driveletter]: /FS:NTFS.
Convert.exe will attempt to convert the partition to NTFS.
NOTE: Although the chance of corruption or data loss during the conversion from FAT to NTFS is minimal, it is best to perform a full backup of the data on the drive that it is to be converted prior to executing the convert command. It is also recommended to verify the integrity of the backup before proceeding, as well as to run RDISK and update the emergency repair disk (ERD).
Microsoft Windows Vista Ultimate Edition Logo
MY LAPTOP IS HP PAVILION dv6 I get the error message vssx80042317 or vss writer failed when I try to run a restore. Also in IE9 when I click on a link nothing happens.
1. Click Start, click Run, type Regedit, and then click OK.
2. Locate and then click the following registry subkey:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\EventSystem\{26c409cc-ae86-11d1-b616-00805fc79216}\Subscriptions
3. On the Edit menu, click Delete, and then click Yes to confirm that you want to delete the subkey.
4. Exit Registry Editor.
5. Click Start, click Run, type services.msc, and then click OK.
6. Right-click the following services one at a time. For each service, click Restart:
  • COM+ Event System
  • COM+ System Application
  • Microsoft Software Shadow Copy Provider
  • Volume Shadow Copy
7. Click Start, click Run, type cmd, and then click OK.
8. At the command prompt, type vssadmin list writers, and then press ENTER.
9. If the VSS writers are now listed, close the Command Prompt window. You do not have to complete the remaining steps. If the VSS writers are not listed, type the following commands at the command prompt. Press ENTER after each command.
  • cd /d %windir%\system32
  • net stop vss
  • net stop swprv
  • regsvr32 ole32.dll
  • regsvr32 oleaut32.dll
  • regsvr32 vss_ps.dll
  • vssvc /register
  • regsvr32 /i swprv.dll
  • regsvr32 /i eventcls.dll
  • regsvr32 es.dll
  • regsvr32 stdprov.dll
  • regsvr32 vssui.dll (does not work in Windows XP)
  • regsvr32 msxml.dll
  • regsvr32 msxml3.dll
  • regsvr32 msxml4.dll
Note The last command may not run successfully.
10. At the command prompt, type vssadmin list writers, and then press ENTER.
11. Confirm that the VSS writers are now listed.
12. At the command prompt, type vssadmin list shadows and then press ENTER.
13. Confirm that there are no errors listed. On Windows XP you should see: No shadow copies present in the system.
14. Congratulations your machine should work again with any VSS compatible programs.
Oct 27, 2011 | Computers & Internet
I can't connect to windows live messenger. what shall I do?
Clear the DNS resolver cache
For Windows XP:
  • On the taskbar, click Start, and then click Run.
  • Type cmd, and then click OK.
  • At the command prompt, type ipconfig/flushdns, and then press ENTER.
For Windows Vista:
  • On the taskbar, click Start, type cmd in the Start Search box, and then press ENTER.
Try signing in again.
Jan 07, 2011 | Computers & Internet
cannot play games (example big fish games) after being downloaded to my pc. I get this message d3derr_notavailable
Your graphics card most likely doesn't support Direct 3D. You can test using the following command in a cmd prompt window dxdiag
In XP click start/run and type cmd in the run box to open a command prompt window.
In Vista/Win7 to open the command prompt, either go through the start menu - click start, All Programs, Accessories, then click on Command Prompt or in the run box type: cmd .
Dec 19, 2010 | Computers & Internet
HOW TO ACESS MSDOS IN MY LAPTOP
Depending on the operating system installed, you can get to a DOS like environment.
  1. In Windows XP, Start, run Type CMD Click OK
  2. In Windows Vista/Windows 7, on the search line type CMD, right click Command Prompt on the Menu above, Click Run as Administrator, Click Accept on UAC prompt.
  3. In Windows 98/Millennium, Start, Run, COMMAND, OK
Dec 27, 2009 | ASUS Eee PC 1000H Laptop
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
378 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
