Tip & How-To about Computers & Internet
How to gain access in newly installed or a stable Windows Xp with administrator account
The following is a very easy tip & trick most of you must know about it it is also a very critical vulnerability which needs to addressed by microsoft the trick is this at the logon screen press CTRL+ALT+DEL and press DEL two times this will open up a User name and password box like those in Windows Server enter Adminstrator as user name and voila you are in user name is not case sensitive in this case.
Computers & Internet Logo
how to update windows xp
Go to Microsoft Update and follow the appropriate instructions.
Jun 11, 2011 | LG Computers & Internet
what is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
Upgrade to XP Pro SP3 necessary?
If you had many problems, it's not necessary, as long as your firewall / anti-virus is configured correctly.
Jul 16, 2009 | Acer Computers & Internet
file error 22001
There does not seem to be a way to fix the files that have been affected but McAfee sent out an email today saying tha Microsoft had posted a patch to IE 7 that prevented unauthorized access via XML code.
As this has been one of the speculated methods in which hackers have caused this "file error 22001" problem (the other being a virus piggybacked on cookies), my guess is that this patch is designed to solve this issue however your files are probably gone.
You can get patch by doing Windows Update inside "TOOLS" on IE7.
Actual text from McAffe notice is below.
Best of luck
Ivan C. "Nick" Camp IV
Director of Global Operations
Wellness International Network, Ltd.
Microsoft has released a patch to address a critical remote-code-execution vulnerability in Microsoft Internet Explorer. The MS08-078 bulletin (Microsoft Internet Pointer Reference Memory Corruption Vulnerability) addresses the vulnerability for Microsoft Internet Explorer versions 5.01, 6, 7, and 8 Beta 2 running on Windows 2000 SP4, XP SP3, Server 2003 SP1, Vista SP1 and certain Server 2008 configurations.
Main threat sources: E-Mail; Locally logged-on user; Web
Threat level: Critical.
Solutions: On December 17, Microsoft released a patch to address this issue.
Dec 18, 2008 | Western Digital My Book Essential Edition...
127 people viewed this tip
David Payne
David Payne
