Tip & How-To about Computers & Internet
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
Computers & Internet Logo
i want to connect my sony tritron tv to my hp laptop
If you Sony TV has a VGA video input socket then connect a VGA video cable to the TV and the other end of the VGA cable to the VGA video connector on your laptop.
Power up the TV and go to the Input selection Menu and select PC connector then boot up your laptop and the Windows video data will automatically to the TV.
You can toggle between the TV the LCD or both by pressing Fn key plus F4 key.
May 29, 2012 | HEWLETT-PACKARD G71340US Laptop
how to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
cannot find a sound cable to go from my laptop to tv
you need a Y-Cable, Phono Plugs to 1/8" Jack
you can get it at radioshack Model: 42-2550
Catalog #: 42-2550
Apr 01, 2009 | Televison & Video
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
317 people viewed this tip
David Payne
David Payne
