Tip & How-To about Coffee Makers & Espresso Machines
How to program Cuisinart to grind or brew?
The procedure is as follows:--For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position. This will help.Good luck.
Coffee Makers & Espresso Machines Logo
how do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
can't find manual, how do you program to brew in the morning?
Each model is different, but the general procedure is to push the PROG button (or turn the dial to PROG), then use the hour and minute buttons to set the time that you want the coffee-maker to go off in the morning. Most models display "PM" if it is set for PM, but don't display anything if it is set for AM. The critical part, on models that have a PROG button, is to push the PROG button AGAIN to store the time. Then turn the unit to Auto-On. It will go off at the set time.
Cuisinart, however, has dozens of different models - it will vary by your exact model number. Most manuals are available on Cuisinart's website.
-Tha Mp3 Doctor
Feb 24, 2009 | Cuisinart Coffee Makers & Espresso...
cna't find manual, how do you program to brew in
-Tha Mp3 Doctor xxx
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
How to program to automatic brew
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
887 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
