Tip & How-To about Audio Players & Recorders
How to unlock SanDisk sansa mp3 player?
There is a hold switch on the side of the player - slide it to the opposite position that it is in now to unlock it. This will help.good luck.
How do i unlock my mp3 player
On the right hand or Left Hand Side You would see a Slide Switch which Might Say Hold/Un hold Or Lock/Unlock Just Slide it to the Other End and Try.
Good Luck!!!!!
Dec 30, 2011 | Sharp Audio Players & Recorders
I can't store photos on my card; it says card locked with a lack symbol on the capture mode
If it uses an SD memory card, look on the side of the card for a switch. It may be in the "Protect" position. Move it to the opposite position.
If this doesn't help, the memory card probably needs to be replaced.
Jul 13, 2011 | HP Photosmart R927 Digital Camera
How would I lock and unlock the mp3 player. I have the Coby MP610-4G player.
The power switch on the side doubles as the lock. Slide it down (away from the "HOLD" position) to unlock it.
Jan 22, 2011 | Coby MP-610 MP3 Player
when turning on the camera. it says the card is locked
If you look at the card itself, you will see that there is a little slide switch to lock and unlock the card. It is there for the purpose of saving the data (pictures) from accidental deletion. Just slide the switch to the opposite position that it is currently in, carefully replace it into the camera making sure it does not get switched back to the lock position, and all should be good.
I hope this helps and good luck!
Mar 25, 2010 | Casio Exilim EX-S880 Digital Camera
Locked MP3 player.
Here is a link to the manual:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
336 people viewed this tip
 Grubhead
Grubhead
