Tip & How-To about Cell Phones
Gsm secrets
Type *#61# and press call - Check call redirection status.
Cancel all redirections: ##002#
*43# to activate call waiting, to deactivate #43#.
If your phone doesn't have incoming call barring and outgoing call barring, you can try this. For outgoing call barring dial *33*barcode*# and pres OK. To deactivate it dial #33#barcode*#.
On any phone on any network type in **43# to enable conference calls. You can make up to 7 calls at once
If you need to block SMS reception (if you are spammed by someone) just press this code: *35*xxxx*16# xxxx is your Call Barring code (default is 0000). To remove this barring type: #35*xxxx#
If you want to hide/show your phone number when calling, put one of these codes below in front of the number that you are going to call. (*#30# / *#31# or *31# / #31# ) Works on some networks.
Typing *0# or *nm# on the beginning of a txt message gives you detailed delivery report on some networks.. But turn off reports in message settings before. When the sim card-pin blocked type **042*pin2 old*newpin2*newpin2*
Important: If you know any other tips & tricks & secrets about GSM mobile or any other mobile which is not listed here then you can post in Guestbook and it will be updated soon with your name.
Warning: You can try these codes at your own responsibility ! We are not responsible for any malfunction and we don't accept any complaints.
Cell Phones Logo
how to deactivate the answer mashine from c6112
Hi!
there is no standard way to do it as the deactivation code is operator dependent.
So the best way is to call up the service line and ask for the code of:
how to cancel redirection of voicemail and they will give you a code in *#***# where *** is some numbers. ask for the reactivation code as well in *****#
key in the code and press call.
Nov 03, 2011 | Samsung C6112 Cell Phone
what is the barring code for Nokia n70?
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off
*#06# IMEI Number showing
**004*DestNo#@ set all conditioned call diverts to DestNo on and active
##004#@ all conditioned call diverts (busy, not reachable, no answer) off
**21*DestNo#@ Automatic divert all calls to DestNo on and active
*21#@ Automatic divert all call DestNo activate
##21#@ Automatic divert all calls to DestNo off and inactive
#21#@ Automatic divert all calls to DestNo deactivate
*#21#@ Automatic divert all calls to DestNo status
**61*DestNo#@ Call divert when not answered on and active
*61#@ Call divert activate
##61#@ Call divert when not answered off and inactive
#61#@ Call divert deactivate
*#61#@ Call divert when not answered status
**62*DestNo#@ Call divert if not reachable on and active
*62#@ Call divert activate
##62#@ Call divert if not reachable off and inactive
#62#@ Call divert deactivate
*#62#@ Call divert if not reachable status
**67*DestNo#@ Call divert when busy on and activate
*67#@ Call divert activate
##67#@ Call divert when busy off and inactive
#67# Call divert deactivate
*#67#@ Call divert when busy status
**03*330*oldPW*newPW*newPW#@ Changing the password for call barring
**33*PW#@ Barring all outgoing calls on (PW one row before)
#33*PW#@ Barring all outgoing calls off
*#33#@ Barring all outgoing calls status
**330*PW#@ Barring all calls on
#330*PW#@ Barring all calls off
*#330*PW#@ Barring all calls status
**331*PW#@ Barring all outgoing international calls on
#331*PW#@ Barring all outgoing international calls off
*#331#@ Barring all outgoing international calls status
**332*PW#@ Barring all outgoing international calls except homecountry on
#332*PW#@ Barring all outgoing international calls except homecountry off
*#332#@ Barring all outgoing international calls except homecountry status
**333*PW#@ Barring all outgoing calls on (PW one row before)
#333*PW#@ Barring all outgoing calls off
*#333#@ Barring all outgoing calls status
**35*PW#@ Barring all incoming calls on
#35*PW#@ Barring all incoming calls off
*#35#@ Barring all incoming calls status
**351*PW#@ Barring all incoming calls if abroad on
#351*PW#@ Barring all incoming calls if abroad off
*#351#@ Barring all incoming calls if abroad status
**353*PW#@ Barring all incoming calls on
#353*PW#@ Barring all incoming calls off
*#353#@ Barring all incoming calls status
*43*#@ Call waiting on
#43##@ Call waiting off
*#43#@ Call waiting status
**61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30)
#30#DestNo@ No presentation of the number of the incoming call (CLIP)
*30#DestNo@ Presentation of the number of the incoming call (CLIP)
*#30#@ CLIP status
#31#DestNo@ Your number will not be send for the actual call (CLIR)
*31#DestNo@ Your number will be send for the actual call (CLIR)
*#31#@ CLIR status
*76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on
#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off
*#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status
*77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on
#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off
*#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Jun 10, 2011 | Nokia N70 Cellular Phone
i want o update my nokia n70 but where....?
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
Jun 03, 2011 | Nokia N70 Cellular Phone
I have this problem, which unfortunately I don't
Try going into your:
1)Settings/Call Settings and de-activate/cancel all diverts.
2) Back out into Call Settings and De-activate/cancel all calls waiting.
You should be fine after this.
Regards,
Sox
May 12, 2010 | Cell Phones
When use search engine, always gets redirected to a different site
I just finished dealing with a similar piece of malware and I may have a solution for you. Please check the following and let me know:
1) Are Yahoo search results also being hijacked/redirected?
2) When redirected, does IE briefly access a server at "r9237242.cn" or some similar address? Watch the status bar at the bottom of IE when being redirected.
Let me know and I can help you out further.
JohnB
Nov 14, 2009 | Microsoft Internet Explorer 8
211 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
