Tip & How-To about Cell Phones
Motorola secret tips
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Cell Phones Logo
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
Thanks for using fixya .
Jan 26, 2011 | Motorola Mobility V360 Cellular Phone
MOTOROLA TIPS
Once my Mobile asked for PUK Code,I contact the Mobile Network Service provider they Provided me that.So You can get it from them.....
Sep 27, 2010 | Cell Phones
my motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 20, 2011 | Motorola Mobility V360 Cellular Phone
special code of motorola nextel i836
hi,
Here are the codes
1) to find out the IMEI number:*#06#
2) this is used to lock keys Press together *7
3)Select phone line - (use this to write things below the provider name):
4)Add phonebook to main menu:
5)Add messages to main menu:
6)Copy SIM memory (phonebook menu):
7)Eng Field options (main menu):
8)Slow (Frequency of search menu):
9)Medium (Frequency of search menu):
10)Fast (Frequency of search menu):
11)Enable EFR:
12)Function :
Change pin:
thank you for using fixya.have a nice day :-)
Jul 24, 2010 | Motorola Mobility i836 Cellular Phone
unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Jan 04, 2008 | Lands Phones
199 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
