Tip & How-To about Cell Phones
Samsung secret tips
If you have downloaded corrupted or incompatible Java midlets or other media,
which are causing problems with the phone, try this
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
The master reset code is:
#*7728#
This will not delete anything from your
mobile phone, but set each and eveything to its
default/standard setting as it was on the time of purchase.
To unlock your phone put a sim from another company,
now type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks.
This code may not work on the older phones and some of the newer phones.
If it doesn't work you will have to reset your phone without a sim in it
by typing *#2767*2878# or *#9998*3855# (not tested)
Other Samsung Codes
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
Cell Phones Logo
RESETARE
Samsung Reset Codes
You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone.
Other Samsung Codes
*#06# IMEI code
Dec 09, 2010 | Samsung Cell Phones
Samsung Secret Codes
thank you so much this is the only thing that helped the problem
Jan 09, 2008 | Samsung SYNC SGH-A707 Cellular Phone
how to reset the Samsung Sway?
Input *2767*3855#
Hope this helps and good luck!
-KC GTO Dad
Sep 18, 2009 | Televison & Video
FORGOTTEN PASSWRD
try this
Tips & Tricks For Samsung :: You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone.
try the FULL RESSET *2767*3855#\
all phone files will be lost
Jan 01, 2008 | Samsung SGH-D600 Cellular Phone
getting my pictures off my phone
try this tricks and codes,
you can earase Pics. by selecting the MEDIA
*2767*63342#
All sound and Pics will be deleted.
Dec 22, 2007 | Samsung SGH-d807 Cellular Phone
203 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
