Tip & How-To about Computers & Internet
Error 161, 163
Errors 161, 192, 163.
All three of these errors are connected to the back up
battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips
screwdriver required)
2. find the small connector with 1 black & 1 red wire
coming from it.
3. disconnect above connector and gently pull the
Red&black wires. The backup battery should just pull out
from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the
packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot
welded so need to be cut/broken off). Buy a new CR2025
battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
(see the one just removed). Solder the leads onto the new
battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all
exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows
161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off
switch at side.
Computers & Internet Logo
error 161 & 163 on ibm aptiva 2168-m62
try this one:
battery.
coming from it.
switch at side.
Mar 05, 2010 | Computers & Internet
i have an error in canon photocopier IR 1210 E 245 where is the problem in the copier
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
Oct 24, 2009 | Canon imageRUNNER 1210 Copier
IBM THINKPAD 600 - How to fix error codes 161 and 163
START WITH THE MACHINE OFF
HOLD and CONTINUE TO HOLD "F1"
WHILE STILL HOLDING "F1" TURN ON THE MACHINE
AND
This will go into bios, you'll get a green and white screen.
Set time and date there, save and exit.
Should work.
Mar 17, 2009 | IBM ThinkPad 600 Notebook
starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
starting ibm 600e
Hi there.
All three of these errors are connected to the back up battery.
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
204 people viewed this tip
David Payne
David Payne
