Tip & How-To about Ovens
Who made your Sears Kenmore Range, Stove, or Oven?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Sears does not make any of its own appliances. They have different manufacturer’s make them for them. To see who actually made the appliance you can check out the model number of your appliance and then look to see who made it.
The first three digits of the model number refer to the manufacturer.
- Roper made appliances starting with these numbers
103
647
835
911
155
-Whirlpool made appliances starting with these numbers
106
110
562
665
198
-Caloric made these
174
960
-Kelvinator made these
417
662
628
-Gibson starts with 253
-D&M starts with 587
-GE made these
363
362
-Speed Queen starts with 651
-Maytag starts with 925
-Litton starts with 747
-Toshiba starts with 562
-Fedders starts with 484
-Amana starts with 596
-WCI starts with 790
-Tappan starts with 791
-Jenn Air starts with 629
This will give you an idea as to who made an appliance. By simply checking the model number and comparing it to this list you can see who made it.
Ovens Logo
has gone bang need a rewiring diagram for it to be fixed
A wiring diagram is not going to help you fix it. You need the knowledge and tools to diagnose the problem before you can fix it.
May 10, 2016 | Ovens
My lamona single oven has stopped working but previously was fine. What can I do please ?
Hello Hayley Wager, fix it.
None of your appliance nomenclature came through with your question...
First avenue to restoration ...
Check your power sources... cycle the breakers
(turn off & back on).
Check your oven settings to make sure they are NORMAL...
No delay or TIMED cooking programs have been invoked.
Clear all settings...
failing all the above... get out your manual and read the RESET instructions...
Failing that read the TROUBLE SECTION...
New manuals can USUALLY by obtained On-Line by
inputting (for a search)
owners+manual+(your make)+(your model)...
likewise: parts/spares... +(your make)+(your model)...
While good information can be had at SEARs my favorite (USA) is
appliancepartspros.com for prices...
Although SEARs is beginning to become competitive... always get three estimates.
My first suggestion.. when buying parts for an oven... on a guess
is the thermostat
You can get a cheap volt-ohm meter and test your heating element...
Not knowing the make and model... I can only say the bake & broil elements are usually different... one work... but not the other means good power & switching (usually the element itself).
Happy hunting...
Sears
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
May 02, 2016 | Ovens
temperature seems to be too hot- 240C have adjusted control knob but no difference. DOn't hear a click when I do this either. Thermostat?
Avril, Temperature control faulty, replace or get another oven.
show your appreciation by pushing the helpful button and follow me on Fixya for more tips and info.
Feb 18, 2016 | Ovens
bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
320 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
