Tip & How-To about Home Security
Beeping CO detector
If you have an alarm system with a CO detector on it and it is beeping every 5 min or so it needs to be replaced, Contact your security alarm company. CO detectors only last 5 yrs. Note: Nothing will be indicated on keypad so be sure it is part of alarm system or you may be charged if tech comes out. When in doubt call them out. : )
Home Security Logo
had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Periodically emits 3 loud beeps. Displays 888.
The CO detectors require replacement of the battery periodically.
Unlike smoke detectors, the detector element itself also requires replacement as well as the battery and is sold as a module with the battery attached.
May 02, 2010 | Kidde Nighthawk Combo Gas/co Detector
kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
ademco security system every few min the carbon monoxide two beep
This could also be the ADT C.O. detector. they onlt last 5 Yrs. At that point they will beep every 5min nothing will display on keypad. Unit needs to be replaced.
Sep 13, 2009 | Honeywell 5804 Ademco Wireless Security...
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
1,533 people viewed this tip
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
