Tip & How-To about Computers & Internet
Notebook Not Powering No Lights
Hey Just Try Removing The battery And Just Unplug Every tHing Means Every Thing And Press The Power Button For 25 Secs>>It Works
>>If Not try Resetting Your Ram And Hdd Definately it would work..
Regards
Sid
Computers & Internet Logo
My laptop does not boot. When I press the power button, Power LED turn on but nothing else happenes. None of the other lights turn on (Caplock, wifi, etc.), the screen is blank, and there is no BIOS beep. I have tried removing the Hard drive, RAM, etc. but had no luck as of yet.
Welcome to Fixya
This happens with all laptops. Try to drain the remaing static energy of the motherboard. Take out the battery then unplug the power adapter form your computer. Press and hold the power button for 10 secs. Put everything back in and turn ON the computer. If same thing will happen then this is already a LCD problem. You may contact our support at 1-877-453-686 press option 2.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 04, 2011 | Lenovo 3000 G530 Notebook
laptop will not turn on
Hey,
Try this, unplug every thing that is connected to the notebook including the power supply. Remove the battery of the unit. Now press and hold the power button on the notebook for 30 to 40 seconds. Now re-connect every thing and try to power up the machine, you should be up and running.
In case if this also does not work, th you may need to visit the service center, as this could be a memory related issue
Jul 10, 2010 | Toshiba Satellite A105-S4384 Notebook
I have replaced the battery with a new one all it will do is the power charging lightjust barly flashes and it wont power up.
first thing, completely shut down your computer. then remove all the accessories. battery and charger. press the power button for 1 minute so it will refressh your settings to default.
Then connect just the charger and turn on your computer. If it powers up means the power adapter is working fine.
You can check the battery.
But if the problem still persist it is a posible hardware issue and you need a technician to physicaly check your computer. It could be the mother board if you cannot see any windows page.
Mar 27, 2010 | Computers & Internet
battery replacement
hi there;
hey try to unplug the power cord from the powersupply now open the case and unplug the powersupply to the the motherboard and then press the reset button on the front for 15 seconds and than connect the motherboard powercable and plug in the powercord back in to the powersupply and try to restart the computer. please tell me if this works and ANY thing that happnes ok best regards mike
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
169 people viewed this tip
David Payne
David Payne
