Tip & How-To about Computers & Internet
How to speed up your windows computer(xp,vista,win7)
This has been a question of a million people that "How can i speed up my computer" so today I will share some small infos that will help you to speed up your windows based pc/notebook/laptop with a very small knowledge about your computer.
#Your computer has some beautiful tools built in to help you speed up your pc. The main reason that makes computers slow are basically less memory, running more service/programs at once and some Regestry error which occurs due to various software install and un-install. Regestry errors makes your computer works more and get less work done. so this is what you could do
#1.open run/search box from the start menu nad type in this" cleanmgr" delete/cleanup the files you want to remove/ you don't need. That will give you some extra space to work with.
#2.Download ccleaner which is free software reomended by various computer experts. install and run the software. It will also help you to cleanup some extra space. you can use the regestry option to check for some simple regestry error and fix those.
#3.Open ccleaner and go to "tools">>startup and change the programs you don't want to start when you start your computer for exmaple. skype,yahoo,fax/printer service etc. This will decrease your computers bootup time.
#4.from the start menu open the run/search box and type in "dfrgui". this will defragment your computer and fix some regestry error.
#5. Download any good regestry cleaner. I will recomend Regestry Mechanics a software made by pctool the same sompany makes the best anti spyware " Spyware doctor".It will help you to fix almost all the registry error.
Now restart your computer and you can feel the difference by your self. thank you!
Computers & Internet Logo
which speed sensor affects the speedometer on 05 trailblazer
It's probably not the VSS - vehicle speed sensor . Does the vehicle shift ok , run good ? The VSS is a input to the PCM - engine computer ,an use's speed info for shift points, fuel control info ,an some other thing's as well . The PCM share's this info over the class 2 serial data bus ! Google GM class 2 serial data bus communication network . GM back in that time had an issue with stepper motor's inside the instrument cluster . Watch this video ! How to repair GM Instrument Cluster Speedometer Gauge Stepper
Aug 19, 2016 | 2005 Chevrolet TrailBlazer
Mac / Bluetooth / Viewty issues
http://docs.info.apple.com/article.html?artnum=306631
To send a file using Bluetooth to a computer running Mac OS X 10.5 Leopard, you must enable Bluetooth Sharing in Sharing preferences. By default, Bluetooth Sharing is turned off in Leopard.
  1. On each Mac OS X 10.5-based Mac, from the Apple menu, choose System Preferences.
  2. From the View menu, choose Sharing.
  3. Check (click) the "On" box next to Bluetooth Sharing.
  4. Close the Sharing preferences window.`Works perfect
Jun 08, 2008 | LG KU990 Viewty
128 people viewed this tip
David Payne
David Payne
