Tip & How-To about Televison & Video
Region free code for Govideo DVR4200
Code 1:
Press pause.
Enter Pi until FF appears (314159).
Enter region desired (0 for region-free).
Press pause again.
Code 2:
Go to DVD mode.
Press Setup/Menu on the remote.
Go to TV Aspect and pick 16:9 Wide.
Hit the corners: type 1397139.
Hit Enter.
Televison & Video Logo
lg hx995tzw multi-region code required
I am unable to locate the specific code for this unit, but each maker frequently uses a single code for all of their models. Here is a setup that works on a bunch of LG models, but not specifically yours:
If the remote controls more than the DVD player, select DVD on the remote
Remove discs from unit, so 'No Disc' appears
Press Pause/Step and 314159
The display will show 'Code' or 'FF'. If not, Press Pause/Step, Enter and then 314159.
Press 0 for all regions
Press the Pause/Step button again
Turn unit off with Power button. Power on again after 30 seconds and the machine will be set to the selected region.
May 09, 2011 | LG Televison & Video
LG DVD Player and DVD Combo Region Code Procedure
Thanks Toddg..that was really brilliant..
I have travel a lot so am very grateful..
Might write a song about you.
M+F
Oct 15, 2008 | LG RH1999H DVD Recorder/HDD Recorder
need region code 1 for lg dvd player model number v181. ddv/vcr player is region 4
1. Remove any disks & Keep tray open.
2. Press the "Pause" button.
3. Key in "314159"
4. Press "0" when you see "Region code" on the display.
5. Press the "Pause" button.
6. Switch off the player.
7. Switch on again. It's now multi-region!
OR
Turn on Player. Make sure the dvd is selected
Open tray
Type 0 (zero) three times
Region Management test code will display
enter 0 for all regions
Press Pause to return
Region free is now activated.
Aug 03, 2008 | Televison & Video
Regional Code
3602
1. Power on,
2. Press "Pause" ||
3. Enter "314159"
4. Press "0" (for region free)
5. Press "Enter"
... the 0 replaces the previous region number in the second line.
6. Press "Pause" ||
7. Power off.
Or
With the unit in DVD mode and the drawer open, key in "0" four times. A two line menu appears with "Edit Region:_" and "Region Code:x". Key in the required region (presumably 0) and press enter. Power off
HT762tz:
http://www.videohelp.com/dvdhacks/lg-ht762tz/9060
May 16, 2008 | Televison & Video
7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Nov 02, 2007 | Insignia NS-PDVD8 Portable DVD Player
173 people viewed this tip
Top Televison & Video Experts
