Tip & How-To about Televison & Video
Region free code for Govideo DVP855
Power unit.
Press Open.
Press Setup.
Highlight Custom.
Press 3333.
A new menu appears called "Secret1".
Select region or choose "0" for region-free.
Televison & Video Logo
dvd8723uk curtis dvd player wrong region
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Sep 09, 2008 | Digix HT1056A DVD
fix for DVD Player
Try making DVD player multiregion
Or
Or
2) Open the tray
Aug 31, 2008 | Digix HT1056A DVD
Curtis region error
This region code solution as per
Or
Or
2) Open the tray
Aug 17, 2008 | Digix HT1056A DVD
region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
138 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
