Tip & How-To about Televison & Video
Region free code for Daewoo DVG-6000D
Code 1:
Put a region 1, 2, 3, or 4 and so on into the player when it comes up with "wrong region". Just push the "title PBC" button on the remote and away you go.
Code 2:
Push on the remote, STOP, STOP, SETUP, >>, |<<, >>|, SELECT REGION.
Code 3:
With the player turned on and no CD, push (on the remote) "set-up, <<, >>, |<<, >>|".
Code 4:
Put in any DVD, when "WRONG REGION" appears, press the 'TITLE' button on remote or player.
Code 5:
1. Press the Open button on your remote control to open the disc tray.
2. Press the Setup button on your remote control.
3. Press the Stop button on your remote control.
4. Press the Previous button on your remote control.
5. Press the Next button on your remote control.
6. A hidden menu will appear where you can select 1 for region 1, 2 for region 2, and so on.
Televison & Video Logo
I purchased dvds from ebay and they will not play on my dvd player. Is there a way i can unlock or change the region on my Sony DVP-SR200P DVD Player? Please help!!!
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Apr 14, 2010 | Sony DVP-SR200P DVD Player
can I make sony NS400D multizone and if not, what does it play...we got it secondhand..ngcosgrove@hotmail.com
on the rear of the player will be a region code plate with a picture of a globe and a number next to it.
Or
Or
Mar 21, 2010 | Sony DVP-NS400D DVD Player
how to region free code for JBL DVD PLAYER CINEMA SOUND 3
The model number would be helpful as well. Below are a few universal process's for JBL dvd players. Not 100% guaranteed..
Give them a try, if they don't work then post the model number for further info.
PROCESS 1
1. Turn on player without disc and wait for "no disc"
2. Press OSD on remote control
3. Press 314159
4. Press 0 for region 0 (or 2 for region 2, etc.)
5. Turn off player with 'off'
6. Ready.
PROCESS 2
1) Open DVD tray
2) Press and hold "6" button on remote control.
3) Press "Menu/PBC" button. The current region code will be displayed on screen.
4) Keep pressing the "Menu/PBC" button until the preferred region code is selected (0,1,2,3,4,5,6).
5) Press and hold the "Angle" button for more than 2 seconds to save the region code. "Writing Region ID" will appear on screen.
PROCESS 3
Volume off
Slide Open
Press volume+ for 3 sec on remote
Then press Language on remote fast
Then choose 0 for region free
Press ok
Good luck , let me know if one of them work. Thank you for trying Fixya!
Mar 21, 2009 | Televison & Video
Coby 514 change region solution
Try these two. they seem like they'll work. Their both for this unit.
Turn unit on with remote
NO DVD in the tray closed or opened might work
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
1. Open the DVD tray
2. Press 'STOP' button on the remote control
3. Press '70'
4. Press 'MENU PBC'
5. Use the numeric keypad to select your region code number (0 – 6). 0 is all regions.
6. Press 'Enter'
Oct 11, 2008 | Coby DVD-514 DVD Player
multi region hacks
Try this may be work
Multi-Region:
Put DVD into player - wait for regional code violation screen to appear
Once this has occurred press the M (Memory) button on your remote
Press 1 for Title 1 and Play on the remote - this will over-ride the regional code violation detection menu
You can watch the movie by pressing Fwd on remote and change chapters by using the T (Title/Chapter) button on the remote)
or
Switch On DVD player without disc in machine
Press Enter
Press 8, 4, 2, 6 and 9
Press Enter
Player should turn itself Off. If not switch it Off
Switch player back On
Mar 05, 2008 | Televison & Video
235 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
