Tip & How-To about Televison & Video
Region free code for Daewoo DHC-2200K
To convert this player to Multi-Region on later firmware versions Press the Open button on your remote control.
Press the Set-up button on your remote control.
Press the 9 button on your remote control for Region Free, or 1 for Region 1, 2 for Region 2, and so on.
Press the buttons 2, 0, 1 and then 0 on your remote control in order, one at a time
If this doesn't work, you should try pressing the buttons 3, 0, 1 and then 0.
If this still doesn't work, you should try pressing the buttons 4, 0, 1 and then 0 instead.
Press the Step button on your remote control.
Press the Shuffle button on your remote control.
Press the Next button on your remote control.
Televison & Video Logo
convert daewoo dvd-vcr mod df-4501pn to region free
I did not find any hack for your model, I don't think there is any I will just doublecheck.
Jul 20, 2008 | Televison & Video
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was recommended nothing happens) 3) a new item saying Version should be there (nothing there saying that) Any ideas please? Chris
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
169 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
