Tip & How-To about Televison & Video
Region free code for JVC XV-511BK
Make sure there is no Disc in the tray.
Shut off the unit and unplug it from the AC outlet.
Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display).
Press DVD Menu twice on the remote.
When the display reads 000 5858 use the up and down buttons to change the 000 to 02E.
Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
Press Enter on the player.
Press Standby and wait 5 seconds.
Press Standby again.
Your player is now set to the region you requested.
If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Televison & Video Logo
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
How do I make player JVC XV-S300 region free.For years it worked fine,but all of a sudden it will not accept different codes. Please help, and many thanks!
hi,
Try the following to make your dvd player region free
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
ok
Feb 17, 2011 | JVC XV-S300 DVD Player
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
error message when reading DVD
Try changing the region setting to region free.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
210 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
