Tip & How-To about Televison & Video
Region free code for Samsung SV DVD1E
Code 1:
Make sure there is no disc in the machine.
Power the DVD on by the remote control (not by the on/off button on the actual player).
Press enter, 8,4,2,6,9.
Press enter.
The Tray will open, insert the DVD.
Code 2:
Always perform a Cold Start before applying the hack below:
Power on your player whilst pressing hold both the Play and Stop buttons on the front player.
After a short while you should be presented with a set of language options.
Release the Play and Stop buttons on the player.
You will now need to select a language option between 1 and 6
Code 3:
Power on your player.
Press and hold both the Play and Stop buttons on the player.
You will now need to select a language option between 1 and 6 to convert this player to Multi-Region playback.
Press the Repeat button on your remote control.
Using your remote control enter the code below (note that you must know what Region your player is currently set to in order to know which code is appropriate):
For Region 1 use 2, 9, 3, 3 and 4;
Ffor Region 2 use 3, 8, 7, 6 and 7;
For Region 3 use 5, 6, 7, 3 and 2;
For Region 4 use 7, 6, 8, 8 and 4;
For Region 5 use 5, 3, 8, 1 and 4;
For Region 6 use 2, 4, 4, 6 and 2;
A code should be displayed on the screen indicating the current Region setting of your unit.
Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Open button on your player.
Press the Standby button on your remote control.
If the player sticks on FBI Warning screens press Forward Search x2 or faster, the disc should skip straight to the main feature.
Televison & Video Logo
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
I would like an unlock code for two vcr/dvd combos. Can you help?
If you need a region free code, here it is:
Make sure you have no disc or tape in
Turn it on.
When the display shows "no disc"…...
1. Press the DVD button on the REMOTE CONTROL so the Samsung DigitALL logo appears on the screen
2. Press the SUBTITLE button on the REMOTE CONTROL
3. Using the REMOTE CONTROL enter the code: 7, 6, 8, 8, 4
4. The current region should be displayed on the screen. (eg "04") If this doesn't happen then turn off
and then on and try again
5. Press the 9 button on REMOTE CONTROL for Region free or new region number
6. Press the Open button on PLAYER
7. Press the Close Tray button on PLAYER.
8. Power the unit off, then power the unit on again
Nov 25, 2008 | Samsung DVD-V4800 DVD Player / VCR Combo
need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
cyberhome dvr 1600 dvd recorder
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
Feb 09, 2008 | Cyberhome DVR 1600 DVD Recorder
255 people viewed this tip
Top Televison & Video Experts
