Tip & How-To about Televison & Video
Region free code for Samsung DVD M103
Code 1:
Switch the player off and on.
Hold the play and stop buttons (for 10 seconds).
Press the Repeat button on your remote control.
Using your remote control enter the code below (note that you must know what Region your player is currently set to in order to know which code is appropriate):
For Region 1 use 2, 9, 3, 3 and 4;
For Region 2 use 3, 8, 7, 6 and 7;
For Region 3 use 5, 6, 7, 3 and 2;
For Region 4 use 7, 6, 8, 8 and 4;
For Region 5 use 5, 3, 8, 1 and 4;
For Region 6 use 2, 4, 4, 6 and 2;
A code should be displayed on the screen indicating the current Region setting of your unit.
Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Open button on your player.
Press the Standby button on your remote control.
Code 2:
Power on.
Press the open/close button, the CD-tray will come out, remove DVD or other CD if present.
Press REPEAT button once.
Enter following numbers: 38767.
Yyou will then see '02' on the TV-Screen.
Press button number: 9.
Press the open/close button.
Power off, then on.
Televison & Video Logo
hello
1. Turn on the device you want to control (vcr, satellite receiver, etc.)
2. Press and hold the button you want to program. While holding the device button, press and hold ON-OFF until the LED on the remote control turns on, then release both buttons.
Note that the AUX button can only be programmed using direct code entry.
3. Point the remote control at the device and press and release PLAY, then wait five seconds or until the LED stops flashing.
At this point the remote control is searching for the correct code to program. If, after five seconds, the device you want to control does not turn off, press and release PLAY again to tell the remote to search the next set of codes.
Continue pressing and releasing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device.
If the device you want to control does turn off:
1. Press and release REVERSE, then wait two seconds. Repeat this step until the device turns back on.
2. To finish, press and hold STOP until the LED on the remote control turns off.
Oct 17, 2009 | Panasonic PV-C2023 20 in. TV/VCR Combo
rca remote with no code search button
You didn't mention the model of the remote so try http://www.fixya.com/support/t839679-rca_remote_no_code_search_button
and see if it is listed.
If this works please repost,
MM85
Jul 27, 2008 | RCA Universal Remote Control
250 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
