Tip & How-To about Televison & Video
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
Televison & Video Logo
i cannot play region 2 with it
please try this to make it region free
Multi-Region:
• Turn On the unit with the remote controller
• Wait until "no disc" appears in the unit's display
• Press Pause, 3, 1, 4, 1, 5, 9
• The word "CODE" should appear in the display
• Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
• Again, within 5 seconds, press Pause and Power
• Put the player into Standby mode
• Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
• Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
• Press Audio and Return for auto-switching On
• Press Angle and Return for MacroVision On
• Press Subtitle and Return for MacroVision Off
please rate me well or ask for more help before rating the solution
Apr 27, 2009 | Sony DVP-NS51P DVD Player
Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
Dec 03, 2008 | Televison & Video
Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
Nov 22, 2008 | Philips DVP 720SA DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
1,641 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
