Tip & How-To about Dishwashers
Dishwasher will not run. Water in bottom does not drain.
Most probable cause is that your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. On newer models it will be located in or near the drain. There will be tube about 2 inches (5cm) and about an inch in diameter with holes in the top. Inside this is the float valve. On older units is looks like a small upside down cup. Lift it and clear anything from underneath. Make sure it can lift and drop freely.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Dishwashers Logo
my indesit dishwasher is filling up with water but not emptying. Seems to be sticking after a couple of clicks on the programme.
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Apr 23, 2010 | Indesit 24 in. D63 Free-standing...
standing water in dishwasher won't start
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Mar 22, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
It filled up with water in the wash cycle then stopped, now it won't cancel and drain the water .
Float valve has triggered. It is most probably jammed or it is doing its job by stopping the machine from over filling. This could be a result of a clog in the machine. Following is the process to check.
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Mar 20, 2010 | Kenmore Dishwashers
I have Kitchenaid kudk03itbl3 model dishwasher. It does not fill with water during cycle.
I will assume there is power to the unit and the water supply is on.
Simple things first and we can go from there.
Float valve is jammed.
Not working?
Pump check.
Timer problem?
Thanks,
Adrian
Mar 14, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
GE Nautilus won't empty water
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Mar 09, 2010 | GE Nautilus 24" Built-in Dishwasher
345 people viewed this tip
Top Dishwashers Experts
