Tip & How-To about Computers & Internet
How to replace an inverter board in a laptop screen.
Your laptop has no display but when you hook up an external monitor the picture is fine on it. If this is true then more than likely you have a bad inverter board. They are available at http://www.impactcomputer.com . They are not that expensive. You could also have a bad LCD screen but my experience has been that most of the time the inverters go bad. One way to tell is to shine a bright light on the LCD screen. At the right angle you should be able to see what should be on it. If you see a display then you probably have a bad inverter board. That doesn't rule out a bad back light but on most new computers you have to replace the display to replace the backlight so it would be a mute issue since the cost would be as much as a new unit.
To replace the inverter board you will have to remove the bezel around the LCD screen. Usually the bezel has a few screws hidden under plastic dots or rubber cushions. Remove any you see and then pry the bezel off. The inverter board should be visible at the bottom of the screen and may be held in with two screws. Remove and replace the inverter, reassemble the unit and you should be back in business.
hardrocko
Thanks for using FixYa.
Computers & Internet Logo
display area blured
It is having a video failure. or screen going bad and unfortunately its part of the motherboard. Hook external monitor to it if good picture then screen bad. If monitor has bad picture then video on motherboard bad and very exspensive
Feb 19, 2012 | Toshiba Satellite L515-S4010 Notebook
The machine is a Gateway NV53 laptop. The display is showing a reddish background with grey to black horizontal bars. Is it the inverter?
No that will be the screen itself. If the inverter is bad you will see a very faint picture.
Hook the laptop to an external monitor, if the picture is fine it is definitely the screen itself. If it still experiencing display problems then it will be the motherboard.
Comment back if you need more help.
Sep 13, 2011 | Computers & Internet
Screen problems
Hi:
The next time your laptop screen is messing up, try to hook the laptop up to an external monitor. If the picture is bad on the monitor too, you have a laptop video card issue. If the picture is good on the external monitor, then you have a problem with your laptop LCD/ inverter.
Nov 11, 2009 | Dell Computers & Internet
301 people viewed this tip
David Payne
David Payne
