Tip & How-To about Televison & Video
Samsung DVD-HD850, DVD-HD841 region free code
1. HDCP-Free: Requires only DVD Remote.
a. Power On DVD player, no disk inserted
b. Press "Angle"
c. Press "4", "3", "2", "7"
d. Press "Angle"
e. TV Screen displays HDCP Free
2. Region Free Hack: Requires AIWA/Universal Remote or PDA
The following instructions are for a Pocket PC
a. Download and install TvRemote
http://www.pdawin.com/tvremote.html
b. Download AIWA Mini Audio CCF file
http://www.remotecentral.com/ftp/ccf_templates/mini_systems/aiwa-mini-nsx999.zip
c. Copy the unzipped CCF file to your PPC
d. Run TvRemote on your PPC.
e. Switch to CCF mode on TvRemote
f. Open the copied CCF file. Screen changes to display
the remote.
g. With DVD switched on but tray closed:
i) Press "Repeat"
ii) Press "Program"
iii) Change remote screen and Press "Clock"
DVD display shows "ADJUST"
iv) Press "9" on DVD remote. I also pressed "9" on the
PPC remote so I'm not sure which one did it.
v) No visual indicators occur on DVD.
vi) Power off DVD.
h. DVD is now region free!
Televison & Video Logo
how can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
we have a sharp blueray DVD player BDHP20X and need code to enable all area DVD's to play, just moved to australia and have a heap of DVD's from uk etc. that won't play on this machine.
There don't seem to be a hack available for this player publicly yet. For sure it is possible to get to play all regions, not yet publicly known how todo. Possibly with a hacked firmware but to my knowledge not yet publicly available or no one has yet to do it.
Jun 30, 2008 | Sharp Televison & Video
unlock toshiba SD800ky
2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
3. Press 2,4,0,3,9,6,0
4. Press 9 for multi-region playback. You will see a "9" appear in the upper right hand corner of the TV. DO NOT Press Enter button on your remote control
5. Press the Open/close button on your remote control to close the drive tray, and power off the DVD player before it says "no disc".
6. Power the DVD player back on and it is region free !!! Woohoo !
Jan 09, 2010 | Televison & Video
dvd dose not play
1. Insert any disc
2. Press Eject on remote (Once you eject, don’t pull the disc out)
3. Press DVD Setup on remote
4. Press 8800 on remote
5. Press DVD Setup on remote
6. Press Angle on remote
7. Region code number (0 : free, 1 : USA, 2: Europe)
8. Press (Skip Fwd) on remote.
Apr 20, 2008 | Blaupunkt IVOD-1022 Overhead LCD Monitor...
391 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
