Tip & How-To about Televison & Video
Samsung BD-1600 region free code
I used it on my brand new Samsung BD-1600 today and it
worked on the first try using the code below.
My unit is a Region 2 (UK) machine.
1) Press the POWER button on the remote to turn on the
machine (no disc in the tray).
2) Wait till the player has booted up and the Samsung logo
screen is displayed.
3) Press the OPEN/CLOSE button on the remote twice, to open
then close the disc tray.
4) As soon as you see "No-Disc" displayed in the top left
corner, press the REPEAT button followed by the 5 digit code
for your current region as listed below.
(Mine was 57538 for region 2)
Don't press the REPEAT button for too long, just smoothly
press REPEAT 5 7 5 3 8.
If it doesn't work straight away, keep trying, mine worked
on the first go.
5) If you're successful, your current region code will be
displayed in the top left corner of the screen.
6) Press '9' to make your player region free.
7) Turn the player off, then on again and test with a
different region disc, or if you don't have one to test
with, just repeat the hack and instead of your old region
code appearing in the top left corner of your screen, you
should see '9' if you've been successful.
The hack can be repeated to turn your machine back to it's
original settings or to a particular region if the disc is
sensative to region free machines.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Televison & Video Logo
Samsung bd-f5100 region unlock code
DVD region Free:
WITH THE REMOTE CONTROL OF YOUR BLUE RAY
1. Power ON. Make sure No disc is showed.
2. Press REPEAT button.
3. Press 7-6-8-8-4 (or your region code).
3. The current machines region code will display at the top left of the screen.
4. Press 9 to change to free region and turn off your player.
Patience. If the above code didnt work, try the below one by one..
1- 29334
2- 57538
3- 56732
4- 76884
5- 53814
6- 24462
Jun 25, 2014 | Samsung Televison & Video
Need Remote Codes for Samsung BD-P1600 DVD Player
Here is the details for my region 2 player.
Use the option below but with my method.
I had to sit like 3 feet away from br player to get the hack to take and its now showing up as region 9.
I also updated my player today when i first plugged it in so hack works with update.
on the first go.
Nov 28, 2009 | Yamaha RX-V2700 Receiver
i want to unlock the region on my samsung bdp 1600 blu ray player
Not sure of this works on the very latest models but here it is :-
on the first go.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Sep 25, 2009 | Samsung BD-P1600 Blu-ray Disc Player
Unlocking of Samsung BD-P1500
I have a new BD-P1500, and after 5 Times
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running
090417_01_BDP1500_XAX.RUF
I used the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now it to me about 5 tries to get this to work, It needed to be done without delay.
So if you don’t get it to work straight away don’t loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Report this hack (requests/questions/spam/wrong/****).-->
Region code hack posted by wasgo, September 17 2008:
I have tried the hack mentioned above on my new BD-1500 and couldn't make it work. But the software in it isicon_minipost.gif about a month newer.
Does anybody have any new ideas how to solve the problem?
I have the region 2 version (Sweden)
Jan 18, 2009 | Samsung BD-P1500 Blu-Ray Player
region code Samsung BD - P1400
1. Make sure the player is switched on, and is at the Samsung logo screen.
2. Also check the tray is shut and that there's no disc in the player.
3. Now press the REPEAT button on the remote, followed by a five digit code.
4. This code is different depending on what region your player is *currently* set to: R1 - 29334 R2 - 38767 R3 - 56732 R4 - 76884 R5 - 53814 R6 - 24462 So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
5. If you've done this correctly (and your player is compatible with the hack), you should see a number at the top left corner of the screen corresponding to the current region.
6. Now, pressing any number from 1 to 6 will change to the corresponding region. Or, press 9 for "auto-region" mode.
7. Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD POWER) on the remote to close it and put the player into Standby mode.
8. The next time you turn your player on, the new region will be set. Don't forget that if you want to hack it again, you'll need to use a different code, as listed above. If it's currently set to "region 9", use the code for the last *proper* region you set it to.
or this...
Multi-Region on a Samsung BD-P1000 R2:
1. Switch on unit
2. Remove any disc
3. Wait fo NO DISC message
4. Press REPEAT on the remote control (NOT REPEAT A-B)
5. Type 57538 followed by the desired region number on the remote control
NOTE: 9 = Multi Region mode
6. Press OPEN/CLOSE on the remote control
Switch unit off
7. Enjoy :0)
Apr 27, 2008 | Televison & Video
409 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
