Tip & How-To about Computers & Internet
Where can I find No Post Diagnostic information for my Dell Desktop/MiniTower system
Most Dell desktop/minitower system have the ability to have no POST failure diagnostics that can assist you in determining exactly what has failed in the system making part replacement easier.
For older Dells that have diag LEDs on the back of the system (labeled ABCD), here is the table indicating diagnostic faults:
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm#wp1052387
For Newer systems where the LEDs are on the front panel (Labeled 1234) the table is here:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
Power LED indications are here:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
Computers & Internet Logo
dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Please my dell optiplex 755 does not power but the on-board light is on. it only has a yellow light always blinking on the power button. how do i solve this problem?
Replace the power supply.
Generally this is a dell diagnostic light feature tellign you the power supply is failing. Have the unit tested and get a replacement.
Jan 24, 2011 | Dell Optiplex 755 Minitower Desktop...
Why would the on/off button be yellow-orange instead of green when the computer is turned on?
Solid yellow-The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed
Blinking yellow- A power supply or system board failure has occurred
post again here if you need further assistance..
Regards..
Jun 28, 2010 | Dell OptiPlex GX520 PC Desktop
six beeps at post and no joy with boot up
The exact meaning of the beeps for Dell depends on their... rhythm.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
Six beeps might indicate a simple CMOS failure caused by a bad battery, which is easy to replace.
Nov 08, 2009 | Dell OptiPlex GX280 PC Desktop
12,924 people viewed this tip
David Payne
David Payne
