Tip & How-To about Televison & Video
Samsung DVD region free code for HD-841, HD-850, HD-860
this hack is from HD-841 and also works with the HD-850. I've just (succesfully) tested it with a HD-860 from Best Buy. You will need a universal remote control (I used PM725S, $8.00 from Amazon but you can get it at Fry's, WalMart, etc.) You need to program the remote with the code 768 (Audio, AIWA). Once this is done:
1) Power on player
2) open dvd tray
3) Press "info/select" button on the Philips remote
The message "Servo adjustment complete" will be displayed on the screen.
4) Press "9" on the Philips remote
All the segment on the display on the front of the player will light up
5) Press "9" again on the Philips remote
The LCD display on the front now says "open"
6) Close the tray.
That's it, enjoy, your player is region free.
Televison & Video Logo
What is the difference between the new Cisco 860 and 880 Series and the Cisco 850 and 870 Series ISRs?
The Cisco 860 and 880 Series routers complement the Cisco 850 and 870 Series by adding support for new technologies such as 3G WWAN, voice, and 802.11n WLAN to the Cisco 800 Series portfolio.
Simply speaking, 860 and 880 Series are the enhanced versions of 850 and 870 Series.
If you have any question about network, welcome to consult in router-switch.com
Sep 27, 2017 | Cisco Computers & Internet
my daughter bought new headphones in America two weeks ago but when she got home bad connection at jack making bad hearing sounds in one of the ears. When you play about with jack connection it improves the sound slightly. the model is HD 201S
Well, there are a few ways to solve this. The easy way would be either to call the manufacturer (At (860) 434-9190, more info here) and see if there is a warranty on the item. Second, you could just buy a new pair, which is probably not the best way. Third, you could actually splice a new jack onto the headphones with a little soldering skill. You'll need to: 1)Cut the ******** the end 2)Strip the wires off the jack (and the replacement jack) 3)Solder the wires together (Matching black to black, red to red, ground to ground, etc)
If you've never soldered before, see if you could get a friend to help. Here is a video tutorial of how to solder, if you wish to attempt this yourself.
May 03, 2011 | Sennheiser HD 201 Consumer Headphones
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
239 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
