Tip & How-To about Cell Phones
Samsung SGH-500 codes
#*6837# = Official Software version
*#9999# = Software version
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#8999*8376263# = HW ver, SW ver and Build Date
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
#*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standard
Cell Phones Logo
need activation code for my qb pos version 9.0
Only Intuit can generate the validation code for POS v9
800-446-8848
Mar 04, 2013 | Intuit QB POS 8.0 BASIC RTAILRS HW/SW Full...
samsung wave S8500 secret codes
You just need to type the codes using Keypad:
*2767*3855#
Think before you give this code. This code is used for factory format. It'll remove all files and settings including the internal memory storage. It'll also reinstall the phone firmware.
PS: Once you give this code, there is no way to cancel the operation unless you remove the battery from the phone. So think twice before giving this code.
*#197328640#
This code can be used to enter into Service mode. You can run various tests and change settings in the service mode.
*#0228#
This code can be used to get detailed information about phone battery.
*#7465625#
This code can be used to check the status of Sim Lock and Network Lock.
Codes to get Firmware version information:
*#4986*2650468# - SW Version, HW Version, MP, RF Cal Date, CSC Version, CSC Model Spec, FFS Version, RC2 Version
*#1234# - SW Version and CSC Version
*#1111# - FTA SW Version
*#2222# - FTA HW Version
Wi-Fi and Bluetooth Test Codes:
*#526# - Wi-Fi Manual MFG Test Mode
*#232337# - BT RF Test Mode
Codes to launch various Factory Tests:
*#0*# - LCD test
*#0673# OR *#0289# - Melody test
*#0842# - Vibration test
*#2663# OR *#2664# - TM Command
Dec 28, 2010 | Samsung Wave S8500 Smartphone
My phone shuts off by itself several times a day. It has even shut itself off during a call. I am constantly checking to make sure it's still on.
What firmware version do you have? Go to "Menu | Settings & Tools | 0. Phone Info | 2. SW/HW Version" and check the {SW Version] shown.
I'm on Verizon, and I've got firmware version 05 (shown as "VX920V05")
Two possible things to try that I've seen suggested:
(1) get a new software update if you don't have the latest version. This has to be done at a Verizon store - they take your phone and updated it with the new firmware;
(2) Turn off, remove battery, and check battery contacts. If the battery is only making intermittent contact, or if it disconnects briefly when shocked or bounced, this could cause the phone to power down. Clean contacts with a clean eraser (blow out the eraser-dust bits...) and try again.
I've seen both of these suggested, and some people who have claimed one or the other worked, but also some who have tried these and still have the problem. So if one or both of these don't work, you could take the phone back and ask for an exchange.
Feb 12, 2010 | LG enV3 VX9200 Cell Phone
SIM LOCK
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
Jun 26, 2009 | Samsung SGH-D600 Cellular Phone
Samsung D820
Here are some codes for your phone....try the first one
*2767*688# = Unlocking Code *#8999*8378# = All in one Code (EDIT) *#4777*8665# = GPSR Tool (EDIT) *#8999*523# = LCD Brightness (EDIT) *#8999*3825523# = External Display (DOES NOT WORK) *#8999*377# = Errors (EDIT) *#2255# = Call List (DOES NOT WORK) #7263867# RAM DUMP ON/OFF (DISPLAY) #*5737425# JAVA SERIAL (DISPLAY) *#8999*5282 JAVA TRACE (EDIT) *#87667# DEBUG MODE (EDIT) *#87927# WAP BROWSER PROFILE (EDIT) DON'T CHANGE UNLESS YOU KNOW WHAT YOUR ARE DOING #*3888# BLUETOOTH TEST (DISPLAY) *#232337# BLUETOOTH MAC ADDRESS (DISPLAY) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock *7465625*782*Code# = Enables Subset lock *7465625*77*Code# = Enables SP lock *7465625*27*Code# = Enables CP lock *7465625*746*Code# = Enables SIM lock *7465625*228# = Activa lock ON *7465625*28638# = Auto Network lock ON *7465625*28782# = Auto subset lock ON *7465625*2877# = Auto SP lock ON *7465625*2827# = Auto CP lock ON *7465625*28746# = Auto SIM lock ON *2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset ^also one time unlock put the non t-mobile sim in the turn it on and type this code to unlock till the phone turns off *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset
Dec 06, 2007 | Cell Phones
151 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
