Tip & How-To about Cell Phones
Bluetooth Connection Guide Part 2
1. To get a connection working you need one last step - you need to connect to the 7650's Bluetooh Serial port from the PC.
2.Right Click on the Bluetooth TM Icon in the system tray, on the menu that appears go to Services and then click on Bluetooth TM Serial Port. Select Find Devices from the sub menu. (A shortcut to this connection will be created so next time you will have the 7650 listed in Bluetooh Serial Port submenu to save the next step).
3. Select the 7650 from list and click Connect.
4. A window will appear telling you the connection is starting.
5. If you have not set the 7650 to automatically authorize a connection from this computer be ready to accept the connection request on the phone. If you have set it to automatically authorize then you won't be asked.
6. You should also see the Bluetooth icon on the 7650 start to flash showing a connection take place. Then you may get an error on the PC saying it can't connect and/or a message saying there is a Connection on COM0 (you can check the box to stop this appearing again), you can just ignore these message(s) for a minute. (Click OK once the mRouter connection is made described below.)
A couple of seconds later the mRouter icon in the tray shows a connection in starting and then a connection being made. You can see also the active connection in the mRouter Connection Properties. The PC Suite application should then be ready for use.
Cell Phones Logo
Muteki 7.2 I turn it on and it read 'USB FAIL'
It is such a hassle when your USB port doesn't seem to be working or when it does not read what's connected to your computer.
You might have a speaker, microphone, keyboard, mouse, webcam, digital camera, joystick or printer that are connected via a USB port.
You are sure you have the device properly connected, and you are confident all gadgets are working well, but still, you can't seem to make it work.
Initially, you need to plug and unplug the device to see if the connection is loose.
But if it still does not work, there are simple steps to fix your USB port.
Shut down the computer, then turn it back on to make sure the device (speaker, microphone, keyboard, mouse, webcam, joystick or printer) is properly connected.
Right click on "My Computer" and choose "Properties."
Click the tab that says "Hardware."
Choose "Device Manger."
Look for "Universal Serial Bus Controller" and click the plus sign before it.
Check if anything has a yellow question mark.
Having a yellow question mark means Windows has detected a problem.
Find your initial installer CD for your PC.
Place it in the CD drive, double click the USB drive and click "update device," and the driver will automatically be updated.
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Aug 13, 2013 | Computers & Internet
GhELLO : I NEED TO DO UPDATED THE BIOS FROM USB PORT?
The USB ports are controlled by the OS. Try the following:
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
Aug 04, 2011 | Sony VAIO VGN-AW330J/H Notebook
my memerysticks stop working when i put in i cannot see my my home work on screen
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 12, 2011 | Computers & Internet
the front 3 usb ports are not working along with all the card readers. In device manager they show to be working properly.
Thanks, Joe
Feb 08, 2011 | HP Pavilion a1130n (PX769AA) PC Desktop
124 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
