Tip & How-To about Cell Phones
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
Cell Phones Logo
hai i used to connect my samsung mobile S3802 to my samsung laptop using bluetooth for connecting to internet using DUN SERVICE.but nowadays i cannot connect through bluetooth.i dont know the problem.can u explain it
Hi Sangeetha,
Please go to:
C:\Program Files\WIDCOMM\Bluetooth Software
and check BTTray file existence / or try to activate it and see what it says... (msg or some error etc.)
Mar 04, 2014 | Computers & Internet
Whenever I log onto windows vista on my hp 6730s laptop with the bluetooth button on and my nokia e51 also with its bluetooth on I get the message three times that drivers for bluetooth peripheral device are missing. howver my laptop and nokia e51 connecgts perfectly through Nokia PC suite as well as OVI. What is the problem and how can I solve it. windows cannot find it automatically online.
It is because the software for your Nokia phone is not yet installed on your computer for the bluetooth connection... This happened to me as well... so you are not connecting via bluetooth just go to your Control Panel and go to Systems then Hardware and then Device Manager under Other devices, uninstall everything and go to your bluetooth devices and remove the Nokia phone that is in the box (Control Panel >> Bluetooth Devices) you should not be asked again for the drivers once you have rebooted after this...
Mar 21, 2010 | IOGear (GBU221) Bluetooth Wireless Adapter
i want anti virus for my phone nokia 5130 express music
down this kaspersky mobile security ;i think it's best for mobile here is the link :http://rapidshare.com/files/310081687/Kaspersky_Mobile_Security.rar
read the discription
Description:
The best antivirus for your mobile.Just install update and kill everything that might try to come in your mobile.
You can use one of the standard methods to install the program on your phone:
1. Transfer the distribution package of the program from the PC to your smartphone via a BlueTooth or infrared connection. Launch the installation of Kaspersky Mobile Security from your device and then follow the installation instructions on the screen.
2. For smartphones based on SymbianOS: If you have the Nokia PC Suite installed on your PC, right-click the distribution package file, select Install with Nokia Application Installer from the menu, and then follow the installation instructions on the screen.
3. For smartphones and communicators based on Windows Mobile: Connect your device to your PC via Microsoft ActiveSync and copy the distribution package of the program to a folder on your device. Use the device’s built-in file manager to launch the installation of Kaspersky Mobile Security.
4. Using a memory card. Copy the distribution package of the program to a memory card. Insert the memory card into your smartphone and launch the installation of Kaspersky Anti-Virus Mobile using the built-in file manager.
TESTED ON NOKIA N-SERIES
TESTED ON WINDOWS MOBILES (O2/HTC/SAMSUNG)
OTHER NOKIA SUPPORTING MODELS
NOKIA
Nokia 3250
Symbian 9.x Series 60 3rd
Nokia 5320 XpressMusic
Nokia 5500
Nokia 5700 XpressMusic
Nokia 6110 Navigator
Nokia 6120 Classic
Nokia 6121 classic
Nokia 6124 classic
Nokia 6210 Navigator
Nokia 6220 classic
Nokia 6290
Nokia 6650
Nokia E50
Nokia E51
Nokia E60
Nokia E61
Nokia E61i
Nokia E62
Nokia E65
Nokia E66
Nokia E70
Nokia E71
Nokia E90
Nokia N71
Nokia N73
Nokia N75
Nokia N76
Nokia N77
Nokia N78
Nokia N80
Nokia N81
Nokia N81 8GB
Nokia N82
Nokia N91
Nokia N91 8GB
Nokia N92
Nokia N93
Nokia N93i
Nokia N95
Nokia N95 8GB
Nokia N95-3 NAM
Nokia N96
O2 MODELS
O2 XDA Atom
Windows Mobile 5.0, 6.0, 6.1
O2 XDA Atom Exec
O2 XDA Atom Life
O2 XDA Flame
O2 XDA Stealth
MOTOROLA MODELS
Motorola ALL COLOR SCREEN MODELS (WITH COM COMPATIBILITY)
Motorola Q
Motorola Q GSM
Motorola Q q9
HTC
HTC
39
HTC 3450 Touch
HTC Breeze
HTC Galaxy
HTC Hermes
HTC MTeoR
HTC Omni
HTC P3300 Artemis
HTC P3350 Love
HTC P3400 Gene
HTC P3452 Touch
HTC P3470
HTC P3600 Trinity
HTC P3600i
HTC P3650 Touch Cruise
HTC P4350 Herald
HTC P4550 Kaiser
HTC P5500 Touch Dual
HTC P6300 Panda
HTC P6500 Sirius
HTC P6550
HTC Prophet
HTC S310 Oxigen
HTC S320 Monet
HTC S420 Erato
HTC S620 Excalibur
HTC S630 Cavalier
HTC S710 Vox
HTC S730 Wings
HTC Star Trek
HTC Touch Diamond
HTC Touch Dual
HTC Touch Pro
HTC TyTN
HTC TyTN II
HTC Universal
HTC Wizard
HTC X7500 Advantage
HTC X7510 Advantage
HTC X9500
Nov 28, 2009 | Nokia 5130 Cellular Phone
WinXP SP2 not detecting bluetooth device
you have to install windows vista again only to enjoy the full function for the notebook coz in windows xp it won't work i to tried this and had faced the same problem in acer travelmate laptop
Apr 22, 2008 | HP Pavilion dv4000 Notebook
152 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
