Tip & How-To about Televison & Video
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
Televison & Video Logo
i have a pioneer dvd player, model DV-380. How can I make it region free.
If you mean to play DVD’s that you may have purchased in another country the see below
For that you need to do a Google for "mymodel region free" or "region free hack"
Not all DVD players are capable of this often very simple modification that many manufacturers build into DVD player. (Usually just involves the remote control and a combination of keys)
Your search will turn up a lot of sharks that want money for the hack (fix)
IGNORE THEM
There are a lot of sites where the information is free.
If after opening up the region free parameter you still have issues and you still want to play your dvd's from around the world you might want to consider another one
I am STILL (lauren) unsure of FIXYA's policy on this topic and am awaiting further clarification on the issue with regards to handing out these codes as this is not HACKING in the same sense as pirate software etc. it is just enabling an extra feature that the manufacturer provided.
I would prefer not to get my @ss kicked. That is why I can only give you the search terms rather than site links or specific information
Aug 30, 2009 | Pioneer DV-380 DVD Player
Hey I'm looking for a code to unlock my onkyo dv-sp302 to make it region free. at this stage it only plays region 4 but i need it to play region 1 as well.....are you able to help?
IGNORE THEM
Aug 26, 2009 | Onkyo DV-SP302 DVD Player
my dvd DV-410v-K will only play region 4
IGNORE THEM
Aug 26, 2009 | Televison & Video
Region Code / DVD Player
DVD-player Sony DVP-NS715P r1/r3/r2-Japan don,t have solderless upgrade
(Example: PDA, DESKTOP, IRC, CD-R and etc....) in
variant MULTIREGION, and NTSC and PAL-enable, and Macrovision OFF.
The modification of this player is done only through special
Sony-Data-service-cable and special firm software through plugs
On main-board (plug CN-103) and on IR-board (plug CN-405).
Mar 19, 2008 | Televison & Video
895 people viewed this tip
Top Televison & Video Experts
