Tip & How-To about Toys
How to use your DS without a stick
The only thing you have to do is get a broke pencil and use that or a color pencil you can also use a inset-a wood think thats staight and when u light it ,it smells. But u can use that or anything staight and holdable
Toys Logo
Wood Burner Flue & stone fireplace building.
You might want to have a professional take care of that. Wrong move and your going to burn your house down
Nov 15, 2014 | Home
When was the pencil sharpener invented?
Before the pencil sharpener was invented, pencils were sharpened by shaving away the wood with a knife. The first pencil sharpener was invented by Therry des Estwaux in 1847.
Oct 06, 2013 | Office Equipment & Supplies
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
FOAM PROBLEM...with your Gaggia coffee machine? No foam?probably the little parts at the end of the turbo frother (plastic bush) was push in when you washed it. So, to repair it, take a wood pencil, introduce it gently by the other end and push out that little plastic thing, that?s what makes the steam to foam your milk. J.M. Coutu May be it will help someboby.
I HAD A FOAM PROBLEM...with my Gaggia coffee machine. No foam. It was the little parts at the end of the turbo frother (plastic bush) witch was push in when I washed it. So, to repair it, I toke a wood pencil, introduce it gently by the other end and push out that little plastic thing, that's what makes the steam to foam the milk.
J.M. Coutu
Jan 28, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
match color of my bike
1999 GL1500SE
Candy Spectra Red, R176C. Inset panel colour is Candy Garnet Red, R199C
Pearl Glacier White, NH326M. Inset panel colour is Glacier White Accent Gray, no code available
Pearl Twilight Silver, NH390M. Inset panel colour is Dark Silver, no code available
Pearl Mercedes Green, G167. Inset panel colour is Dark Green, no code available
Gloss Black, NH1Z
Mar 29, 2009 | 1999 Honda GL 1500 SE Gold Wing
144 people viewed this tip
Top Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
