Tip & How-To about Computers & Internet
Install two operatting windows systems
Make your two partition
from boot-abile dvd or cd , make two partition,after format each and install the first windows os.After your fresh install windows is finishing whit all programs again the first step and install on the second partitition which in most cases is d.
working 200%
Computers & Internet Logo
how to reformat..?
These steps are for formatting your primary drive (normally C:\) in Windows 2000, XP, Vista, and Windows 7 and to reinstall the operating system.
The easiest way to format your computer is by locating your operating system CD. Look for a CD or DVD that specifically says "Operating System" or "System Restore". Insert the installation disc into your CD or DVD drive.
Restart your computer.
When your computer is restarting, you will be prompted to "Press any key to boot from CD". Simply press any button on your keyboard when you see this message. If you do not see this message when you restart your computer, you may need to reset your boot disk sequence. *
*To reset the boot sequence, go into BIOS mode. To do this, restart your computer and while restarting press the F1, F2, F10, or maybe the delete key (your computer screen will say "To enter setup press xxx". You only have a few seconds to press the correct key, so if you miss it you will need to restart your computer and try again. Once you have successfully entered the BIOS mode, look for your boot sequence options. Set the CD ROM drive to be the 1st in the boot sequence. Save your changes and exit.
The CD will load a blue screen, then after a few minutes will ask you to press Enter to set up Windows.
You will then be prompted to select where to install Windows. There will be a box on the lower half of your screen that will either show "Unpartitioned space xxxMB" or will have "Partitioned space xxxMB". Highlight which partition you wish to format (typically it will be the unpartitioned space or the space with the largest partition by most megabytes). Hit Enter after selecting the space to partition.
The next step is to choose which file system to format the drive with. The NTFS option will be the fastest option. For most formatting purposes, choose the option that ends in "Quick". Press Enter when done.
The computer will then begin the formatting process. This process may take a while depending on the size of the hard drive you are formatting and the speed of hard drive.
As soon as the drive has been formatted, the operating system files will be copied to the hard drive and the operating system will start installing.
Nov 13, 2010 | Computers & Internet
i m lookin for installing dual boot with Vista ultimate n Windows 7, gotta dvd for both, any help??
If you wan to fresh install, here you can do ::
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD: Vista Ultimate
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
Format the drive by pressing L, and then create three partition , 100 GB for Vista Ultimate, 100 GB for Windows 7 and rest for data.
Hit enter and let os Load
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
OS will boot and register it with microsft. create login and then remove OS DVD,
Insert the Windows 7 DVD
restrt the system, Hit enter when it says " enter any key to continue"
select new installation, point to the earlier created partition for windows 7 installation
proceed with same procedure.
after complete installation, when you restart the pc, you will find both the BOOT entries at booting.
do not forget to load device drivers on both the OS.
Enjoy!
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
Mar 03, 2010 | Computers & Internet
Uninstallation of Windows Vista ultimate Edition
Just boot from the installation cd. when prompted to repair or don't repair choose don't repair on the next step you'll asked to format the hardisk or leave the current partition. if you dont have any important data I recommend to format your hardisk. Backup yaour data before installing
Mar 21, 2009 | Microsoft Windows Vista Ultimate Edition
acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
128 people viewed this tip
David Payne
David Payne
