Tip & How-To about Video Game Consoles & Games
How to Connect to Wi-Fi (Nintendo DS And Nintendo Wii)
NOTE: For Windows Vista only.
Go to task manager,where it says search type in CMD.
Click it open,and then type in'
IPCONFIG/ALL
then,get your DS Wi-Fi game,take all the info from there to your DS.
Now test your connection!
Video Game Consoles & Games Logo
error code 52100
Hi there! There are a couple options you could try to solve this problem!
To solve this error :
I would first check Nintendo's special notes router infomation page located here.
  • If you can't locate your router on Nintendo's special notes router information page, log into your router and change the basic rate to 1-2 and the transmission rate to 2. Try to connect again.
  • You can try to manually assign an IP address to the Nintendo DS as another device may be sharing the same IP address of the Nintendo DS.
  • To manually assign an IP address to the Nintendo DS, on a PC click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter. The IP address for the Nintendo DS must be 10 digits higher than your PC, for example 192.168.1.200 becomes 192.168.1.210. Also make sure that the correct DNS is the entered under the DS manual settings.
Hopefully one of these options is your answer and you can easily fix your problem! Good luck! If you need any further assistance I would suggest calling Nintendo at 1-800-255-3700.
Jun 03, 2011 | Nintendo DS Lite
I can't connect to a wireless internet. I think it's a problem with the driver. The model is a663, Toshiba Satellite. I've download a wi fi driver and intalled it, it worked for a few minutes and then the internet crashed again. Thanks, Bah.
It could be caused by conflicting software, if you have your device software and windows software trying to setup wifi connections.
Check on the task bar for two icons and right click on one of the icons and select disable.
My wifi device actually works better using windows to configure wifi so give them both a try.
If this is not the problem try renewing IP address,
Click Start on task bar,
click the Run... icon
type cmd in the box and click ok
in the cmd box type ipconfig /release
then ipconfig /renew
Aug 22, 2010 | Toshiba Computers & Internet
Wireless adapter has no isp address
First Reset Your IP
Open Start.. choose RUN..type CMD...press Enter..
In the Command Window, Type: ipconfig /release.. Wait for it to finish, then type: ipconfig /renew
note: You Must Put A Space After ipconfig(space)/release...ipconfig(space)/renew........
Then Check Your Network Settings and Uncheck: Automatically Connect To A Network from your wireless settings....
If Still Having Issues... Go To Your Device Manager and Uninstall The WiFi Adapter/Driver... Reboot and Reinstall..
note: If you uninstall the driver, make sure you first went to the acer website and downloaded the wireless driver and saved it somewhere so that upon uninstall and reboot.... you have the driver to reinstall....
Nov 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
I was lost my task manager in vista home basic how can i get it again pls help me
Hit the start button and type "taskmgr". That should bring up your task manager.
Apr 22, 2009 | Microsoft Windows Vista Ultimate Edition
i want to release my ip adress and refresh it hopeing to get fresh ip or diffrent ip adress
If your on Windows XP open Run and type cmd, when the command prompt opens type:
ipconfig /renew (please note the space between ipconfig and /
If you using Windows Vista:
Press The Windows button.
Type CMD
Right Click CMD.EXE and Select Run as administrator
Select Continue when prompted by User Account Control
Type ipconfig /renew
and it should release and renew IP address.
Mar 24, 2009 | Dynex DX-E401 Router
178 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
