Tip & How-To about Computers & Internet
HOW TO DISMANTLE A SONY VAIO PCV-W SERIES DESKTOP COMPUTER
Start by depressing the button on the rear panel and sliding off exposing any memory modules.Peer between the lower locating lugs for this panel and you will see that it has revealed two black cross-head screws.Take out the screws and release the small panel.This will now expose the four gold colored anchorage screw for the screen and keyboard.Now unplug any i.d.e, sound and visual harnesses between the two units.Using a long phillips screwdriver,take out the four screws and give a small wiggle.The screen and keyboard will come away from the main desktop,place to one side.Now turning the desktop on it's back release the two cross-head screws underneath and slide the foot off.Now take out the six silver screws from the front of the unit and the two either side of the unit.Their are also two screws concealed underneath the rubber lugs on the rear of the unit,carefully pop these lugs out with a blade or similar and remove screws.The last two screws are black and are located in the small recesses on the top of the desktop outer shoulders.Once all case screws are removed gently release locating clips on top of the rear casing and ease the main casing away from video and pcmcia panel on the side,place to one side.This will now expose several black screws,First release the side cover and put to one side.release the three retaining screws for the hard drive unplug molex(power) connector and i.d.e cable,place to one side.Now unscrew the three black screws on the top retaining plate of the desktop and the two screws on the lower shoulders.You can now gently ease out the entire motherboard assembly unplugging atx connector in doing so.PLEASE NOTE:JOT DOWN THE WHEREABOUTS OF SCREWS FOR RE-ASSEMBLY.
Computers & Internet Logo
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
remove or reset dell latitude c640 bios password
How to reset The Latitude C640 Bios password?!
1.First flip your laptop over and remove the battery, as well as any cables connected to the laptop.
2.Remove the screw latched into the memory panel on the bottom of the computer found near the rear.
3.Lift the panel off and expose the memory modules.
4.Seek for a small push-button and press it, holding it for about two seconds. Reassemble your laptop and start it up.
Thank You!
Feb 01, 2011 | Dell LATITUDE C640, P4...
replace a belt
at the very front corners of the console you will see 2 phillips head screws holding the console down(newer dryers have these in the rear).If you do not see the screws then they hidden under the endcap of the console. These endcaps are very easy to pop off. Just insert a flathead screwdriver under the top rear of the endcap, and pull towards you. After the endcap is off the screws will be at the base of the console. After the screws are out you can flip the console backwards, exposing three 1/4" screws (left)(middle)(right) near the rear panel that must come out so you can slide the top forward(not up) off the machine. Once all this is complete you will see 2 screws on the front panel(left)(right) side and your door switch wiring. Also you must take off the lower front panel to expose the other 2 screws that hold the front panel on. And this should give you full access to everything. ***warning*** there are a few newer styles still that do not use screws or endcaps but rather a small metallic clip that must be depressed with a putty knife(rarer style) If that is the case once you depress the clips in the lower corner(under the console), the rest of the teardown is the same as I have just explained!! Hope that helps
Aug 26, 2010 | GE Profile DPSB620ECWW Electric Dryer
I need instructions on how to take apart the sony vaio pcv-w1
START BY SLIDING PANEL OFF TO REVEAL MEMORY MODULE.NOW LOOK DOWN JUST BEHIND SCREEN,YOU WILL SEE 2 BLACK SCREWS.UNDO THE SCREWS AND RELEASE SMALL PANEL.NOW UNPLUG WIRING HARNESSES ALLOWING THE SCREEN TO BE DETATCHED.WITH PANEL MISSING YOU SHOULD HAVE EXPOSED 4 GOLD SCREWS.CAREFULLY WITH A LONG PHILLIPS SCREWDRIVER RELEASE SCREWS.THE SCREEN WITH A SMALL WIGGLE WILL NOW BECOME DETATCHED.RELEASE THE FOOT OF THE P.C BY UNSCREWING 2 PHILLIPS UNDERNEATH,THEN PROGRESS AROUND THE UNIT TAKING OUT ALL BLACK AND GOLD SCREWS.THERE ARE ALSO TWO SCREWS CONCEALED UNDER THE RUBBER LUGS ON THE BACK SIDE OF THE P.C.JUST REMEMBER WHERE YOU HAVE TAKEN SCREWS FROM.ALL THE BEST TECH HEADS charlie c
Dec 15, 2009 | Sony VAIO PCV-W510G PC Desktop
Waste ink absorber needs replacing.
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
if that doesnt help......
power on the printer, open the front door, and open the top lid, centering the printhead carrier.
- unplug the printer, leaving the carrier centered.
- remove the power cord.
- remove and seal your print cartridges. Use vinyl electrical tape to seal both the bottom circular outlet, and the top vent. Bag them in an airtight baggie, preferably storing them in the upright position.
- remove and bag the printhead in an airtight baggie as well.
1. Leave the front door and top lid open
2. Remove both side panels as follows:
- the side grey trim wraps around the top rear of the printer.
Where it ends, slide it up to unclip it from the printer. If you open the top paper feed door, you can see a slot with an arrow below the grey trim. It doesn't really snap up, but slides sideways. Just get this end unclipped first.
- now, under the top lid, you'll see a two slots with an arrow, one on each side. In the slot, you'll see grey-coloured plastic. This is a tab holding the side panel to the frame. Using a screwdriver, insert it in the slot and depress the grey plastic tab while gently tilting the top of side panel away from printer.
- once you have both the rear trim piece and top tab unfastened,
all you need to do is unhook the lugs at the bottom of the silver trim of the side panel, one in the center, and one at the front. Pull up gently on the side panel to disengage these lugs. Place the side panel aside.
- repeat for the other side panel.
3. Remove the top half of the case as follows:
- there are four clips that fasten the top half of the case, two lugs at the back and two clips at the front. You must disengage the front clips first. The front clips are located on each side of the paper exit slot, below the inner door, behind the front fascia. You can't see the clips, but you will see two spots at the bottom of the front fascia where the plastic is 'scalloped' to clear the paper exit slot. Place your thumbs in these scallops, as close to the bottom as you can, wrapping your hand around the edge of the case. Gently pull the front plastic by your thumbs away from the printer, and lift up on the case. It should disengage, but do not lift it up yet. Just get it unclipped (note: the control panel is not part of the top case half, and will remain with the bottom half).
- at this point, it's time to disengage the lugs at the back of the printer. Using a screwdriver, depress the lugs behind the slots on each side of the rear door, and lift the rear of the case. Just get it disengaged.
- once all four clips have been disengaged, lift the top half of the case straight up. Note that the control panel is attached to the bottom half of the case, and will not come off with the top half of the case. Place the top half of the case aside.
4. Now, take a look at your printer from the top. There are a couple items you should be aware of, and be careful not to damage. There is a clear film disk on the left side of the printer which is used to control the platen roller. It has very fine markings on it, which are read by an optical sensor. Do not touch it. Ditto for a clear film strip that runs across the printer behind the printhead carrier, which is used to control the carrier. Don't touch this one either. To proceed. you should be able to see four (4) silver Philips screws, one roughly in each corner, that fasten the printer frame to the bottom half of the case. The front two and the right rear one are easy to locate and get at, but the left rear screw is located between the power supply and the frame, and is difficult to reach. To make it easier,
remove the power supply as follows:
- unplug the wire harness at the top of the power supply.
- place the printer on it's back side, exposing the bottom of the printer.
- on the bottom of the printer, locate the two clips holding the power supply in place.
- depress these two clips and slide out the power supply from the bottom of the printer.
- place the printer back in an upright position.
5. Now it's time to remove the printer frame from the bottom case:
- remove the four Philips screws securing the frame to the bottom
case.
- being careful not to touch the film disk on the left of the printer, and the film strip across the printer behind the printhead carrier, use both hands to lift the printer frame from the bottom case by the metal bar across the top of the printer. Place it on a wad of newspaper, as the bottom of the printer frame may be full of ink.
This will expose the bottom of the case, where you'll find the ink absorber pads. There are many pads, as shown in this replacement ink absorber kit (Canon part QY5-0144-000) available online. Just Google the part number. Write down their appearance and position, because trust me, you won't remember their exact position when you go to put them all back in after cleaning. It's important, because their
position controls the flow of waste ink. I recommend you wear latex gloves or similar, because the ink is indelible. There are also other ink pads in the printer mechanism you might want to look into cleaning or replacing. Get a Canon service manual, and the parts catalogue for all the part numbers. You'll need the service manual to reset the ink absorber count anyways. See www.2manuals.com for example, you can
download both for $10.
To reassemble your printer, just reverse these instructions. I'd also recommend cleaning the printhead before replacing it in your printer.
There are plenty of methods available online, but the method I prefer is using isopropyl alcohol (NOT rubbing alcohol which looks similar).
have a nice day..
Jul 08, 2009 | Canon Office Equipment & Supplies
241 people viewed this tip
David Payne
David Payne
