Tip & How-To about Computers & Internet
HOW TO GET ANY WINDOWS PASSWORD
Here are the full details.....
this works whether its windows 2000 or windows xp or windows xp SP1 or SP2 or windows server 2003....
this works even if syskey encryption is employed...
if it is FAT filesystem...
just copy the sam file like stated in the first post to an empty floppy disk and take it home. I'll tell u what to do with it later... DON'T DELETE THE ORIGINAL SAM FILE. just remove its attributes. the sam file is a file called SAM with no extension. YOU MUST ALSO GET.... a file called SYSTEM which is in the same folder as SAM. both files have no extensions...
if it is NTFS....
u have to download a program called NTFSPro.... it allows u to read from ntfs drives... the demo version allows read only. the full version is read-write.... you use the program to create an unbootable disk (so u will still need another bootable disk and an empty disk) that has the required files to access NTFS.
use the boot disk to get into dos, then use the disks created with ntfspro to be able to access the filesystem, then copy the SAM and SYSTEM files to another empty disk to take home....
AT HOME: u have to get a program called SAMInside. it doesn't matter if it is demo version. SAMInside will open the SAM file and extract all the user account information and their passwords, including administrator. SAMInside will ask for the SYSTEM file too if the computer you took the SAM file from has syskey enabled. syskey encrypts the SAM file. SAMInside uses SYSTEM file to decrypt the SAM file. After SAMInside finishes, u still see user accounts and hashes beside them. the hashes are the encoded passwords. Use SAMInside to export the accounts and their hashes as a pwdump file into another program, called LophtCrack. it is currently in version 5, it is named LC5. the previous version, LC4 is just as good. u need the full or cracked version of the program. LC5 uses a brute force method by trying all possible combinations of letters numbers, and unprintable characters to find the correct password from the hashes in the pwdump file imported into it from SAMInside. This process of trying all passwords might take 5 minutes if the password is easy, up to a year if the password is long and hard (really really hard). LC5 howver, unlike LC4, is almost 100 times faster. both can be configured to try dictionary and common words before using all possible combinations of everything. Once the correct password is found, it will display the passwords in clear beside each account, including administrator.
I use this method so many times. I've compromised the whole school computer infrastructure. LC4 usually took between 1 second and 10 minutes to find the passwords because they were common words found in any english dictionary. I haven't used LC5 yet.
If there is anything unclear, anything I overlooked, plz tell me so that I can turn this into a very easy to follow tutorial to help anybody crack any windowz pass.
Programs needed: SAMInside (doesn't matter which version or if demo)
LC4 or LC5 (lophtcrack)( must be full version)
NTFSPro (doesn't matter if demo)
any bootdisk maker
Cracked or full version software can be found on any warez site. If u don"t know what that is or where to get the programs, post a message and I'll tell u or give them to u.
P.S: I might not keep track of this forum, because I'm going to create a new topic and post tutorial there. if u want to post, plz post there.
Computers & Internet Logo
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the machine the problem reappears... pls give me a solution to fix it permanantly. Thank you.
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
i'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
Dec 31, 2010 | Computers & Internet
Cannot update from XP Home SP1 to SP2 or SP3
start out with a xp home disc that has sp3 already Intragated on the disc - windows xp home SP3
Sep 03, 2009 | Gigabyte GA-K8VM800M Motherboard
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
DOWNLOADING WINDOWS XP FROM THE NET
hi, if your computer has a operating system you can download  xp sp2 from the microsoft website
http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
just copy and paste
hope this helps
Aug 29, 2008 | Microsoft Windows Server Standard 2003 for...
216 people viewed this tip
David Payne
David Payne
