Tip & How-To about Computers & Internet
How to improve Windows XP performance in 6 short steps?
Though the computers of today are strong enough to handle and run Windows XP, with all the visual enhancements enabled, some old computers, or systems with low amount of physical memory and/or a "weak" graphic cards could (and would) run more smoothly with those "cosmetic visual enhancements" disabled.
The default setting is to let Windows choose what's best for your computer, but in 90% of the time, "helping" it a little will surely improve your computer performance!
To disable those visual enhancements, all you have to do is follow the following 6 short steps:
  1. Right-click on My Computer and choose Properties.
  2. Go to Advanced tab.
  3. Click Settings, under Performance section.
  4. Choose Adjust for best performance.
  5. If you would like to keep the "Windows XP Style" (as oppose to "Windows Classic" = Windows 98/Windows 2000 style), you will need to re-tick the 2 last options (Use drop shadows for icon labels on the desktop and Use visual styles on Windows and buttons). This will keep the nice graphical interface and will preserve Windows XP "fancy look".
  6. Click OK on Performance Options window, then click OK once again, to close System Properties.
  • You can always turn the visual enhancements on by repeating steps 1-4 and choosing Let Windows choose what's best for my computer.
  • To make ALL visual enhancements on, choose Adjust for best appearance instead.
Note: Changes take effect immediately, no reboot required.
Another side-issue regarding visual styles is the wallpaper, or Desktop Background.
Having no background (a solid color. Select None in the background's settings under Desktop tab in Display Properties) will demand less resources from the computer and increase response time when showing the Desktop. On the other hand, having a large-size (both in scale and in file size) photo will need more resources (especially memory) to rescale and view/reload it, every time the Desktop is shown.
Computers & Internet Logo
my b933 cant detect any internet sim .i want to know how to fixed .and how openline?
Hi Brian, I'll try to help. Your Dimension XPS B933 computer is running a very old Operating System. At the very best, you could run Windows XP if you did all the necessary upgrades. Your computer was designed to run Windows 98/NT/2000 OP systems and has a 933MHz Pentium III CPU and a fixed 128 MB of ram. This being said, the advancements in technology and programing today render the B933 incapable of using such advancements to the degree that it can not even handle most required programs to operate properly. May I suggest purchasing a newer computer with no less then Windows 7 as it OP system. Because of the length of time that the B933 has not received updates from Microsoft, your computer most likely requires servicing from a technician. Thank You.
Feb 08, 2014 | Computers & Internet
what kind of pc should i buy?
Well, Currently I have an Acer AOA 150, those freaking old netbooks run the visual studio 2010 obviously with windows 7 installed, but basically from now on you can buy any computer with windows 7 [Laptop or Desktop] most of'em will run VS2010.
Jan 23, 2012 | Computers & Internet
we want to work with microsoft windows xp
You should have no problem upgrading with this card.  You can find the drivers for it here:  http://downloads.guru3d.com/download.php?det=406
However, you will find it difficult to get support on this old card.  I suggest investing in a new one.  Just keep in mind AGP or PCI.  See the picture below for a visual representation of the difference.  If you have an AGP port (should be brown) on your motherboard, you really should use it, you will notice a marked difference in video response times vs. PCI.  PCIe/PCIEx/PCI Express is only going to be found on newer computers, however, the visual representation here shows the difference between PCI and AGP.  Note how the connections are stacked on the AGP card.
Oct 23, 2007 | 3dfx Voodoo2 1000 (12 MB) Graphic Card
129 people viewed this tip
David Payne
David Payne
