Tip & How-To about Computers & Internet
How to know if you're Windows/Office system is genuine/legit?
Software piracy has became a wide-spread phenomenon in the last years, especially due to the internet and data on it becoming more and more available to a growing number of computer holders around the globe. Computer technicians and computer stores who want to make or just want to "make a favor for a friend" install pirated software, often without letting the owner of the computer know about it.
It won't be far away from the truth saying that 2 of the most common pirated programs worldwide are the Windows operating system and Office (in all their versions) - both by the huge software company - Microsoft.
Microsoft decided, quite long ago, not to stand still, but to take an active part in the fight against illegal use of its products. They put a critical/mandatory "update" in the Windows Update updates list called "Windows Genuine Advantage Notifications". If your system is configured to get updates automatically (this is the default setting), you'll get this update within the next automated updating. Once installed on a pirated Windows system, notifications will appear very frequently, on the Desktop, in the notifications area and during logon (Welcome screen).
Few examples:
Same goes for Office. Once "Office Genuine Advantage Notifications" if installed, the following will appear in the upper section of any Office program.
For example:
Pirated systems of Windows and/or Office will keep having these notifications until they're fully licensed.
Furthermore, No updates - apart from automated critical updates - will be allowed to be installed through Windows Update or Microsoft Download Center.
Moreover, no Desktop background will be shown (only solid black);
On Windows Vista and Windows 7 - Aero themes will be also disabled.
Not sure if your Windows is Genuine? Want to check if your Office is eligible for full updates? Follow these steps to find out:
1. Download Microsoft Genuine Advantage Diagnostic Tool from HERE
2. Run the tool.
3. Click Continue.
After few seconds you'll see the results.
If it doesn't say Genuine in Windows tab or in Office tab - your software is NOT legit!
What to do in case you have an illegal software?
The good news is that you don't necessarily need to format/reinstall everything! All you have to do is to purchase a GENUINE copy of your version of Windows and/Office and replace the pirated key with the new one. If you purchased the software but found out that it's pirated, contact your reseller for redress!
To change Windows key on Windows XP:
  1. Download Keyfinder.
  2. Run it.
  3. Click Options.
  4. Select Change Windows Key.
  5. Type in the new key.
  6. Press OK.
  7. Restart your computer to complete the process.
To change Windows key on Windows Vista or 7:
  1. Click the "Windows" button ("Start").
  2. Type in: cmd
  3. Right-click cmd on the list and select Run as Administrator.
  4. Type in: slmgr -ipk xxxx-xxxx-xxxx-xxxx (where the "xxxx" stand for the new product key).
  5. Type in: exit.
  6. Restart your computer to complete the process.
To change Office key:
  1. Make sure all Office programs are closed.
  2. Click Start (or the "Windows" button).
  3. Type in: REGEDIT (on Windows XP click Run and then type in).
  4. On 32-bit versions: Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Office\XX.0\Registration. On 64-bit versions: Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\XX.0\Registration. XX.0 represents Office version: 10.0 = Office XP; 11.0 = Office 2003; 12.0 = Office 2007; etc.
  5. Delete the following keys: ProductID and DigitalProductID.
  6. Exit the Registry Editor.
  7. Start any Office program. Enter the new key in the dialogue box that will appear on the screen.
Computers & Internet Logo
what is trojan horse virus
A Trojan Horse is full of as much trickery as the mythological Trojan Horse it was named after. The Trojan Horse, at first glance will appear to be useful software but will actually do damage once installed or run on your computer. Those on the receiving end of a Trojan Horse are usually tricked into opening them because they appear to be receiving legitimate software or files from a legitimate source. When a Trojan is activated on your computer, the results can vary. Some Trojans are designed to be more annoying than malicious (like changing your desktop, adding silly active desktop icons) or they can cause serious damage by deleting files and destroying information on your system. Trojans are also known to create a backdoor on your computer that gives malicious users access to your system, possibly allowing confidential or personal information to be compromised. Unlike viruses and worms, Trojans do not reproduce by infecting other files nor do they self-replicate.
Please rate the solution if helpful. Thank you
Source: http://www.webopedia.com/DidYouKnow/Internet/2004/virus.asp
Jun 17, 2011 | Computers & Internet
I have Samsung R590 Laptop which i bought December last year... Before the USB ports used to work properly and display wt ever data is present in the usb ... but now it reads the data but all appear as shortcut and when i tried to opened it ... it always displays that window cannot open the folder!! Please suggest!!!
Microsoft Knowledge Base
Article 971029
describes an update to Autorun that restricts AutoPlay
functionality to CD and DVD media. This update is intended to stop AutoPlay
functionality from working on USB drives, external hard drives, or network
shares. This update is available for supported editions of Windows XP, Windows
Server 2003, Windows Vista, and Windows Server 2008.
Removable USB/thumb drives use the Autorun feature to load files when the drives are plugged into the USB port. Malware exploits the Autorun feature to spread from thumb drive to PC. Disable the autorun feature to prevent malware from spreading.
The preceding describes what has likely happened to your USB ports due to Windows update disabling the autorun feature for USB thumbdrives. The thumbdrive may no longer present its data properly unless you manually invoke the autorun in its root.
Mar 27, 2011 | Computers & Internet
317 people viewed this tip
David Payne
David Payne
