Tip & How-To about Computers & Internet
CD/DVD drive is missing or not recognized by Windows or other programs...
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loadTOCNode(1, 'resolutTo fix this problem automatically, download Microsoft fixit from here
OR
Windows Vista
  1. loadTOCNode(2, 'resolution'); Click Start, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  1. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. Exit Registry Editor.
  8. Restart the computer.
Windows XP
  1. loadTOCNode(2, 'resolution'); Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click yes.
  6. Exit Registry Editor.
  7. Restart the computer.
Computers & Internet Logo
my problem is only sound driver of my hp pavilion dv5215us Entartainment Notebook Pc. IT HAS NO SOUND
Method 1: Use the Windows XP Sound Troubleshooter How to fix it automatically
To fix this problem automatically, click the Fix It button, and then click the Run Now button. Then, follow the steps in the FixIt wizard.
a.button { background: url("/library/images/support/KBGraphics/PUBLIC/cn/FixItButton.jpg") no-repeat scroll 0pt 0pt transparent; width: 139px; height: 56px; display: block; cursor: pointer; }a.button:hover { background-position: right bottom; } Fix this problem
Microsoft Automated Troubleshooting Services: Diagnose and fix sound playback issues
Note This wizard may be in English only. However, the automatic fix works for all language versions of Windows.
Dec 31, 2010 | HP Pavilion dv5215 Notebook
excel gives error "compile error" excel 2007
There are a bunch of compile errors.
Here is the most common since you did not include the entire error...
This problem may occur when the following conditions are true:
  • The Microsoft Office Startup folder or the Microsoft Excel Startup folder contains either or both of the following Adobe Acrobat PDFMaker add-in template files: Pdfmaker.dot
    Pdfmaker.xla
  • Norton AntiVirus software is installed.
Method 1: Download the latest version of the add-in for Adobe Acrobat 5.0 loadTOCNode(2, 'resolution'); To obtain an updated add-in for Adobe Acrobat 5.0, visit the following Adobe Web site: http://www.adobe.com/products/acrobat/update.html (http://www.adobe.com/products/acrobat/update.html) Note Microsoft does not support downloading and installing add-ins from the Adobe Web site. If you need help, you must contact Adobe Technical Support. uparrow.gifBack to the top Method 2: Move the files loadTOCNode(2, 'resolution'); Move the Pdfmaker.dot file and, if present, the Pdfmaker.xla file from the Office or Excel Startup folder to a different folder on your hard disk. For example, you can move the files to the My Documents folder.
To have us move these files for you, go to the “Fix it for me” section. If you would rather fix this problem yourself, go to the “Let me fix it myself” section. Fix it for me loadTOCNode(3, 'resolution'); To remove these files automatically, click the Fix this problem link. Click Run in the File Download dialog box, and follow the steps in this wizard.
Fix this problem
Microsoft Fix it 50303
Note this wizard may be in English only; however, the automatic fix also works for other language versions of Windows.
Note If you are not on the computer that has the problem, you can save the automatic fix to a flash drive or to a CD, and then you can run it on the computer that has the problem. Let me fix it myself loadTOCNode(3, 'resolution'); Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
To remove these files yourself this, follow these steps.
  1. Click Start, point to Search, and then click For Files or Folders.
  2. In the Search for file or folders named box, type pdfmaker.dot pdfmaker.xla.
  3. In the Look In box, click the disk drive where Windows is installed, such as C:, and then click Search Now.
    The Pdfmaker.dot file is located in one of the following folders:
    • C:\Program Files\Microsoft Office\Office\Startup (Word 2000)
    • C:\Program Files\Microsoft Office\Office10\Startup (Word 2002)
    • C:\Documents and Settings\User Name\Application Data\Microsoft\Word\Startup
    The Pdfmaker.xla file in located in one of the following folders:
    • C:\Program Files\Microsoft Office\Office\Xlstart (Excel 2000)
    • C:\Program Files\Microsoft Office\Office10\Xlstart (Excel 2002)
    • C:\Documents and Settings\User Name\Application Data\Microsoft\Excel\Xlstart
  4. In the Search Results window, right-click the file for each file that is found, and then click Cut.
  5. On your desktop, right-click the My Documents folder, and then click Paste.
uparrow.gifBack to the top Method 3: Visit the Symantec Web site for Norton Antivirus information and product updates loadTOCNode(2, 'resolution'); To resolve this behavior, visit the following Symantec Web site for more information and product updates: http://www.symantec.com/support/index.jsp (http://www.symantec.com/support/index.jsp)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Watches
low sound
Method 1: Try another sound device loadTOCNode(2, 'resolution'); If possible, plug a different output device into the computer. For example, if you have been using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the device itself.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original output device and the issue is resolved. If you cannot hear sound, plug the original output device back into the computer and go to method 2.
Method 2: Use the Windows XP Sound Troubleshooter loadTOCNode(2, 'resolution'); Windows XP includes a troubleshooting program which could help you resolve your sound issues. Start the Windows XP Sound Troubleshooter automatically or manually and then answer each question on-screen in order to try to find a resolution.
Step 1: Start the Sound Troubleshooter loadTOCNode(3, 'resolution'); If you are already familiar with Windows XP Help and Support Center, click the following link to start the Sound Troubleshooter:
OR
Start Sound Troubleshooter manually by using the following steps:
  1. Click Start, and then click Help and Support.
  2. Under Pick a Help Topic, click Fixing a problem.
  3. In the navigation pane on the left, click Games, sound, and video problems.
  4. In the topic pane, on the right side, click Sound Troubleshooter.
Step 2: Use the Sound Troubleshooter loadTOCNode(3, 'resolution');
  1. Click the option that describes the problem that is occurring, and then click Next.
  2. Repeat step 1 until your problem is resolved or until you have reached the end of the troubleshooting path.
    Note You can click Back at any time to repeat the last step, or you can click Start Over to start the Sound Troubleshooter again.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 3.
Method 3: Update your Media Player software loadTOCNode(2, 'resolution'); If the sound problem that you are experiencing occurs when you use a media player such as Microsoft Windows Media Player, try updating your media player software. To obtain the latest version of the Windows Media Player, visit the following Microsoft Web site: http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx (http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx) Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 4.
Method 4: Update sound drivers loadTOCNode(2, 'resolution'); Out-of-date sound drivers may cause sound problems. Check whether an updated sound driver is available. You can use Microsoft Update to help you determine your current sound driver and if an update is available. Then contact the sound driver hardware or the computer manufacturer to request an updated sound driver.
To find out whether applicable driver updates are available, visit the following Microsoft Windows Update Web site: http://update.microsoft.com (http://update.microsoft.com) If the sound driver is out of date, follow these steps to find the name and provider of your sound driver:
  1. Click Start and then click Run.
  2. Type dxdiag in the Open box, and then click OK.
  3. Click the Sound tab.
  4. Under Device, look for Name, and under Driver, look for Provider.
  5. Click Exit.
Contact the manufacturer of the sound driver to request an updated sound driver.
For information about your hardware manufacturer, visit the following Web site: http://support.microsoft.com/gp/vendors/en-us (http://support.microsoft.com/gp/vendors/en-us)
Regards,
Pcs365.8
Jun 22, 2010 | Microsoft Windows XP Home (vis-winxph) for...
svchost exe application location error instruction at 0x00d896bc
This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1 loadTOCNode(2, 'workaround'); Leave the svchost.exe - Application Error dialog box open, and then follow these steps. Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS) are correct loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, point to Run, type services.msc, and then click OK.
  2. In the details pane, locate and double-click Automatic Updates.
  3. Click the Log On tab.
  4. Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
  5. Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
  6. Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
  7. Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, click Run, type REGSVR32 WUAPI.DLL, and then press ENTER.
  2. When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
  3. Type the following commands in the Open box, one after the other, and then press ENTER after each command:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder loadTOCNode(3, 'workaround'); The temporary folder of Windows Update may be corrupted. In this case, you can rename the temporary folder of Windows Update. To do this, follow these steps:
  1. Click Start, click Run, type cmd, and then press ENTER.
  2. At the command prompt, type net stop Wuauserv, and then press ENTER.
  3. Click Start, click Run, type %windir%, and then press ENTER.
  4. In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
  5. At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
uparrow.gifBack to the top Method 2 loadTOCNode(2, 'workaround'); Follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Automatic Updates tab.
  3. Click Turn off Automatic Updates, and then click OK.
  4. Restart the computer.
  5. Use the Windows Update Web site to install updates manually.
  6. After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
Dec 26, 2008 | Computers & Internet
74 people viewed this tip
David Payne
David Payne
