Tip & How-To about Audio Players & Recorders
Harmony remote not charging
If your Harmony remote is not charging on the base, try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Harmony 880 not charging
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. If that does not work, then you will probably need a new charger. Good news is that they are only about $10 if you buy it right from Logitech. You can call their sales line at 1-800-231-7717.
Hope that helps you out.
Apr 05, 2010 | Logitech Harmony 880 LCD Remote Control
started flashing on charger and then shut down now will not charge or come on
Hope that helps!
Dec 18, 2009 | Logitech Harmony 890 LCD Remote Control
Remote not charging on screen, has a picture of a
Also, I would suggest a firmware update.
Hope that helps!
Dec 15, 2009 | Logitech Harmony One Advanced Universal...
The remote charger isn't working
Hope that helps!
Oct 29, 2009 | Logitech Harmony 880 LCD Remote Control
Cant charge my Logitech 1000i
If you have compressed air, try to blow into the end of the power cable that plugs into the charging base as well as the the charging base port for the power cable. Make sure that you don't shake the can or moisture will result, otherwise give it a little bit and replace the power cable into the charging base. How long have you had the remote? Logitech is real good about warranty issues.
Thanks, 81
Jun 22, 2009 | Logitech Harmony 1000 LCD Touchscreen...
256 people viewed this tip
 Grubhead
Grubhead
