Tip & How-To about Cameras
What to do after dropping water onto your Camera??
Do's
  • Switch OFF your device
  • Take battery / memory card out
  • Send your device for service (repair)
Don't
  • Do not insert cell or battery in your camera because it damages (short-circuit) your device.
  • Do not connect your device to computer or any other device.
Cameras Logo
Why my memory card don't work
It maybe faulty. Test the memory card by inserting it into an USB memory card reader and the connect it to the USB port on a working computer.
If the computer does not see the memory card as an external storage device then the memory card is faulty.
Feb 27, 2012 | LG Cell Phones
nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
Please help me. When i insert sim card in my sonyericsson s710a it will hange. Please tell me what to do
Hello,if when you insert the sim card the phone accepts it and shows the mobile network but still hangs then I suggest the sim card needs a replacement or you visit a repair engineer for sim slot servicing.
May 18, 2011 | Cell Phones
have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
taking a picture
Choose the photos to move ro memory card and change the phone settings to send the photos to phone memory..
May 11, 2008 | Motorola Mobility RAZR V3
142 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
