Tip & How-To about Cell Phones
Hard reset the Nokia N97Switch-off your cell then pressing the Caps shift, Space bar, Delete button and Power button while booting up.
Cell Phones Logo
Hi, whenever I connect a USB cable (even charger) the E72 is locked
ITS A SOFTWARE PROBLEM. RESET YOUR PHONE . HOW TO RESET YOUR NOKIA E72
The way to button-press Hard Reset your E72 is the SAME as the N97.
Hold these buttons:
- Capslock
- Space
- Backspace
and Press the power on. As usual, keep the buttons pressed and voila!
NUMBER 2
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation
Feb 10, 2012 | Nokia E72 Smartphone
i need the reset code to preform a factory reset
soft resetting :
-Back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your N97 back to all previous settings
From menu:
Settings> Phone>Phone Management>Factory Settings
hard resetting:
The traditional method won't work as the N97 doesn't have the old keypad. After you've backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You'll know it's worked when you see the initial set up screen, asking country of origin.
Nov 08, 2010 | Nokia N97 Cell Phone
My N97 mini phone restarts whenever i access any application. It's really pathetic. I have upgraded the firmware to latest version, but still the problem persist. Required your help in resolving the issue.
i would suggest you perform a hard reset on your phone by smalteneously pressing
  • Caps shift
  • Space bar
  • Delete button
  • On button
just remember to back up any data you need before that.
Regards
Sep 11, 2010 | Nokia N97 mini Smartphone
my n97 didnt work after i change my theme to mystic theme. it only can show nokia logo and get hang till i open and put the battery off. need help,please
Change the boot IC which is present near back of the phone near the battery connector..This is will work 100%.
Have you tries hard reset?
Some times it may be due to corrupted firmware..This will take back to Factory settings
Switch off
press these four buttons at same time and follow the screen
On button, Right Shift, Space bar & delete
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 30, 2010 | Nokia N97 Cell Phone
last night i play my phone now my phone is lock already so how can i open my phone( Input phone lock code ) can you help me? my number is +60169961600
  • Caps shift
  • Space bar
  • Delete button
  • On button
OR you can try entering this code as if you were making a call *#7370#
www.usedcellphoneshop.com
May 28, 2010 | Nokia N97 mini Smartphone
153 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
