Tip & How-To about Televison & Video
The Philips GO-Gear unit is got stuck frozen?
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off.Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab.Reset the player one more time while connected to computer. Follow the repair instructions. This will help.Good luck.
Televison & Video Logo
my philips gogear wont turn on
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 14, 2009 | Philips GoGear SA5285/37 Digital Media...
when i turn on my player message comes "wait for USB connection". How should i fix it?
2. Reset the player
-Tha Mp3 Doctor
Mar 11, 2009 | Philips SA6025 Digital Media Player
philips gogear mp3 8gb
Make sure the hold/lock is not engaged first.
Run a Repair using the updated version of the Philips Device Manager on Philips website - www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 31, 2009 | Philips GoGear SA5285/37 Digital Media...
good morning, my go gear is stuck, it will not allow me to operate any of the buttons. It just stay on one screen, and the computer does not recognize the go gear Hello. I'm having the same problem with my daughter's Philips Gogear sa3025/37. She was listening to voice recordings when the Gogear froze up. It is now stuck on one screen and my computer doesn't recognize it when it's plugged in.
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Jan 06, 2009 | Audio Players & Recorders
I cannot get the device manager to recognize the player
Make sure that the hold.lock is not engaged.
If not, then get the latest version of the installation software from Philips website.
Sep 09, 2008 | Philips GoGear HDD075/17 MP3 Player
489 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
