Tip & How-To about Computers & Internet
How to print a test page from a printer from windows xp operating system?
1. Go to the start bar.2. Click on the control panel and choose Printer and Fax.
4. Right click on your printer and click on its properties.
5. Click on the General tab and look toward the bottom of the box. Click on the “Print Test Page” button and your printer will automatically print it for you.
This will help.Good luck.
Computers & Internet Logo
prints very lite even after new color and black cartridge ?
Hi Good day.. Maybe your printer head was not properly clean my solution for you is to clean it by using the head clean in the printer properties... please do the following:
1. 1. Click the Start button at the lower left corner of your screen.
2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
4. The Printing Preferences has five tabs across the top; choose Maintenance.
5. Click the Head cleaning, and then click clean again. to start the cleaning.
When the cleaning is done you can print a test page. and see if your print page is fine..
if it's not, you must clean it again... hope my solution will help you..
Regards
JR
Oct 06, 2010 | Office Equipment & Supplies
Printer stopped printing and says its off line!
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
rizwan84tx@gmail.com
Dec 06, 2008 | HP DeskJet 722c InkJet Printer
Problem printing
The toner cartridge roller may be defective or there are outside light going inside the printer, causing the bands.
Mar 05, 2008 | HP LaserJet 1018 Printer
printer in error mode
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 21, 2007 | HP DeskJet 5650 InkJet Printer
123 people viewed this tip
David Payne
David Payne
