Tip & How-To about Office Equipment & Supplies
How to reset the waste ink counter for canon ip 250 printer?
the system is as follows:-- 1. First Disconnect printer from AC power outlet. Also disconnect USB PC cable from back of the printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
This will help.Good luck.
pixma mp 130 - the waste ink absorber is almost full
Try this
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
9. NOW...Open "Printers" and make sure that a "copy" of the printer (MP150) had been made. Make that COPY your default printer and all should work.
Let me know if this works for you. Thanks.
Sep 29, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a 6200 series hp photosmart printer. It is stuck in the shutting down mode. How do i fix it?
Please try the following solutions and keep your fingure crossed:
1. Conect the printer directly to the wall outlet
2. Power cycle:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet. and check the functionality.
3. Semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Jun 10, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My Canon i250 printer suddenly began to print blue not yellow on a yelow hightlighted document. I have installed a fresh colour cartridge but the probelm remains. Please can you help.
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...
Nov 18, 2009 | Canon i250 InkJet Printer
Canon i250 printer problems
Mar 03, 2008 | Canon i 550 InkJet Printer
518 people viewed this tip
k24674
