Tip & How-To about Office Equipment & Supplies
HOW to reset the waste ink counter of canon ip 2000 printer ?
The step by step procedure is as follows.Read the procedure first properly .understand it.then follow it properly without any mistake. 1) Start with the power off
2) Hold down the ON/OFF button plus the RESUME button at the same time.
3) Keep your fingers on both buttons and THEN let go of the resume button.
4) Then press the resume button twice
5) And then let go of the OFF/ON button (which you have been holding down while pressing the resume button twice).
6) Then,first press and release the resume button 4 times
7) And then the power button 2 times after this.
The printer should now be okay and the lights will return to normal (solid green only).
This will help.Good luck.
What are the steps involved in FSSAI License procedure?
Various steps involved in FSSAI License procedure are given below:
1. Business planning
2. Identification of annual turnover for the food business.
3. Understanding the type of license required
4. Completing the documentation
5. Payment of challan
6. Submission of documentation
7. Inspection process
8. Follow-up and license completion.
Aug 21, 2017 | Cell Phones
DELL INSPIRON 1750 stuck in start up loop error code OFOO:
HI,
Could be you just need to update your drivers, before you take it apart try this:
Follow the steps mentioned below to check what Updates are installed on the system.
See which Windows updates are installed
http://windows.microsoft.com/en-US/windows7/See-which-Windows-updates-are-installed
Error Code 0F00:133C
Msg: DISK- No suitable disk media is present.
This error message is encountered when you probably have a bad video card and/or flaky RAM.
Step 1:
Unplug all the External devices such as printers, scanners etc and check whether you encounter this error message.
Step 2:
I would suggest you to install the latest drivers for the Video card from the dell website and check
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
For further reference check the article mentioned below.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 3:
Iwould suggest you to configure Chkdsk to run when the system restarts next time. Follow the steps mentioned below to configure Chkdsk to run when the Windows Vista restarts next time.
a.Click Start and then Run.
b.In Open, type cmd and then press ENTER.
c.Use one of the following procedures:
Procedure 1: To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
Procedure 2:To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note: If one or more of the files on the hard disk are open, you will receive the following message:
a.Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
b.Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Procedure 2: To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
I got this information @ 0F00 133C Error Code No suitable disk or media is present written by Thahaseena M, Microsoft Answers Support Engineer.
Feb 16, 2014 | Dell Inspiron Computers & Internet
how do i reboot toshiba without the cd
Hello, please follow the step,
Toshiba System Restore Vista Step 1 - "Initiating the HDD recovery procedure"
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.
Choose the entry "Repair your Computer" and press "Enter":
2. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and click on "Next".
If unsure, just click on "Next".
3. the following screen a window with your username appears.
Type your windows password as you would log on to your account and press "OK":
4. The next screen offers several options to repair or diagnose your computer system.
To start the recovery, click on "Toshiba HDD Recovery":
Step 2 - Performing the HDD recovery
1. After passing the previous screen, you will be asked if a backup of your important data is already made.
You can continue with the recovery process by clicking on "Next"
2. Confirm the following screen also by clicking on "Next"
3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
Step 3 - Finishing the recovery process
1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
2. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly installed system and to finish the installation of the operating system
FOR WIN 7 Toshiba System Restore Windows 7
How to recover a Toshiba with the HDD recovery procedure
- Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
Bit
The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
"HDD recovery procedure".
Please note:
First of all, make sure you already back up your important data!
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
click on "Next".
1. In the following screen a window with your username appears.
1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
1. Confirm the following screen also by clicking on "Next"
1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
appear.
1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
Hope this helps,
Hope this helps,
Jan 25, 2011 | Toshiba Computers & Internet
I want to restore my notebook pc to the factory settings.
hello dear, before you can restore your PC to the factory settings you will follow these steps below, but first be sure you have backed up all your necessary files because during the restoration all files and data will be lost.
1. Restart the pc
2. at the bios display press F11
3. wait for the system to load windows files necessary for the restoration
4.follow the restore wizard and make sure you read and understand
5.before installation will be successful, all procedure must be positive and terms and agreement must be agreed.
thanks.
Dec 22, 2010 | HP G60-230US Notebook
84 people viewed this tip
k24674
