Tip & How-To about Office Equipment & Supplies
The Printer picks up multiple paper from the manual feed tray?
The reason is as follows:-- The pad that is responsible for separating the paper has likely worn out and needs to be replaced. The pad is located in the printer where the end of the paper reaches in the tray.You can order and install a new pad without sending the printer out for repair. It is also possible that the paper is wet due to humidity. Make sure the paper is properly stored and that it is “fanned” before putting it into the printer. this will help.good luck.
What is the reason Drawer 1 feeding two or more papers in photocopier canon 2320L
The separation pad is probably worn out. This pad creates friction against the bottom of the paper stack to stop multi-feeding.
Aug 28, 2016 | Canon Office Equipment & Supplies
the printer is on and it sounds like it is printing but the paper isnt going through
You must have a worn PICK UP ROLLER or a worn SEPARATING PAD both made of rubber, you could try cleaning them with RUBBER CLEANER (you can use care wiper cleaner pads) both devices are located usually where the paper are fed in the printer, if it works better, you should order a maintenance kit for your printer and replace them...
Feb 09, 2011 | Lexmark X2600 InkJet Printer
When I try to pring something--letter or envelopes, it tries to bring through several sheets at a time.
The pad that is responsible for separating the paper has likely worn out and needs to be replaced. You can order and install a new pad without sending the printer out for repair. It is also possible that the paper is wet due to humidity. Make sure the paper is properly stored and that it is "fanned" before putting it into the printer.
Jan 10, 2011 | Office Equipment & Supplies
paper jams every time
Have you tried printing a page from the hand feed tray ( if you pull down the front door you can feed it thru there.) take the paper out of the internal paper tray
Oct 28, 2010 | HP LaserJet 1320 Printer
Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
138 people viewed this tip
k24674
